[Bio] / Sprout / DBConvert.pl Repository:
View of /Sprout/DBConvert.pl
Revision 1.3 - (download) (as text) (annotate)
Tue Feb 5 05:47:32 2008 UTC (12 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, rast_rel_2009_05_18, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
Removed obsolete use clauses.
#!/usr/bin/perl -w
=head1 DBConvert
This script converts an ERDB database definition to a PPO database definition.
An options is provided to also generate the PPO files from the generated XML.
Two positional parameters are required. The first is the name of the ERDB
XML file and the second is the directory in which to deploy the PPO database.
For example, the following command
    DBConvert -ppogen=ppo_v19_Sprout SproutDBD.xml SproutPPO
will convert SproutDBD.xml to an XML file called SproutPPO.xml in the same
directory, and will deploy the database in the directory SproutPPO. The
database name will be C<ppo_v19_Sprout>.
The currently-supported command-line options are as follows.
=over 4
=item user
Name suffix to be used for log files. If omitted, the PID is used.
=item trace
Numeric trace level. A higher trace level causes more messages to appear. The
default trace level is 2. Tracing will be directly to the standard output
as well as to a C<trace>I<User>C<.log> file in the FIG temporary directory,
where I<User> is the value of the B<user> option above.
=item sql
If specified, turns on tracing of SQL activity.
=item background
Save the standard and error output to files. The files will be created
in the FIG temporary directory and will be named C<err>I<User>C<.log> and
C<out>I<User>C<.log>, respectively, where I<User> is the value of the
=item h
Display this command's parameters and options.
=item phone
Phone number to message when the script is complete.
=item ppogen
If specified, the PPO database files will be generated from the generated XML. The
value of the parameter is the target database name.
=back
=cut
use strict;
use Tracer;
use Cwd;
use File::Copy;
use File::Path;
use FIG;
use ERDB;
use PPOGenerator;
# Get the command-line options and parameters.
my ($options, @parameters) = StandardSetup([qw(ERDB) ],
                                              trace => ["2", "trace level"],
                                              phone => ["", "phone number (international format) to call when load finishes"],
                                              ppogen => ["", "name of the target PPO database; if specified, the PPO database will be deployed"]
                                           "<dbdFile> <targetDirectory>",
                                           @ARGV);
# Set a variable to contain return type information.
my $rtype;
# Insure we catch errors.
eval {
    my ($dbdFile, $targetDirectory) = @parameters;
    # Insure we can find the input file.
    if (! -f $dbdFile) {
        Confess("Input XML file $dbdFile not found.");
    # Insure the target directory exists.
    if (! -d $targetDirectory) {
        Trace("Creating target directory $targetDirectory.") if T(2);
        mkdir $targetDirectory;
    # Compute the location for the PPO XML file. It's placed right next to the target directory.
    my $targetXmlFile = "$targetDirectory.xml";
    # Call ERDB to convert the database.
    ERDB::CreatePPO($dbdFile, $targetXmlFile);
    # Check to see if we should deploy the database.
    if ($options->{ppogen}) {
        # We're deploying, so do it.
        Trace("Deploying PPO database as $options->{ppogen}.") if T(2);
        PPOGenerator->deploy($targetXmlFile, $targetDirectory, $options->{ppogen});
    Trace("Conversion complete.") if T(2);
if ($@) {
    Trace("Script failed with error: $@") if T(0);
    $rtype = "error";
} else {
    Trace("Script complete.") if T(2);
    $rtype = "no error";
if ($options->{phone}) {
    my $msgID = Tracer::SendSMS($options->{phone}, "DBConvert terminated with $rtype.");
    if ($msgID) {
        Trace("Phone message sent with ID $msgID.") if T(2);
    } else {
        Trace("Phone message not sent.") if T(2);
1;
