[Bio] / Sprout / CustomAttributes.pm Repository:
Log of /Sprout/CustomAttributes.pm
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Tue Sep 9 21:01:25 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.35: +1 -1 lines
Diff to previous 1.35 , to selected 1.21
Added new-line at EOF
Wed Sep 3 20:53:19 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.34: +30 -22 lines
Diff to previous 1.34 , to selected 1.21
Fixed to delete duplicate attribute results.
Wed Aug 13 15:47:32 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.33: +4 -2 lines
Diff to previous 1.33 , to selected 1.21
Fixed a bug in the handling of generic patterns in the value list.
Tue Aug 12 06:06:02 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.32: +669 -586 lines
Diff to previous 1.32 , to selected 1.21
Converted to new multi-table design concept for attributes.
Fri Jan 25 19:00:58 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.31: +128 -37 lines
Diff to previous 1.31 , to selected 1.21
Changed to do mass deletes and loads in bursts for better performance.
Changes since 1.30: +34 -34 lines
Diff to previous 1.30 , to selected 1.21
Fri Oct 5 01:40:58 2007 UTC (12 years, 2 months ago) by parrello
Diff to previous 1.29 , to selected 1.21
Changed to prevent accidental queries for the entire database.
Wed Oct 3 05:23:37 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.28: +2 -0 lines
Diff to previous 1.28 , to selected 1.21
Changed load method to stop checking for duplicates after it finds the first new attribute when in resume mode.
Sun Sep 30 20:52:51 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.27: +38 -29 lines
Diff to previous 1.27 , to selected 1.21
Removed transactioning from the load process.
Sun Sep 30 03:46:30 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.26: +13 -0 lines
Diff to previous 1.26 , to selected 1.21
Added timings to the statistics output.
Mon Jun 11 18:44:40 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.25: +47 -0 lines
Diff to previous 1.25 , to selected 1.21
Fixed PDB load to make PDB IDs case-insensitive. In some attributes the PDB ID is upper case; in some it's lower case.
Sun May 6 10:16:52 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.24: +1 -3 lines
Diff to previous 1.24 , to selected 1.21
Fixed a bug that may have been causing the Safari problem.
Fri Apr 27 22:17:39 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.23: +68 -1 lines
Diff to previous 1.23 , to selected 1.21
Added a QueryAttributes method that allows filtering for attribute values using SQL syntax.
Mon Apr 23 06:26:54 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.22: +5 -0 lines
Diff to previous 1.22 , to selected 1.21
Fixed to skip lines without value columns.
Tue Apr 10 05:19:20 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
Revision 1.21 - (view) (download) (as text) (annotate) - [selected]
Sun Feb 18 22:13:53 2007 UTC (12 years, 9 months ago) by parrello
Diff to previous 1.20
Fixed a bug in the file handle detection code.
Sun Feb 18 21:25:37 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.19: +342 -219 lines
Diff to previous 1.19 , to selected 1.21
Updated for subkey support.
Fri Feb 9 22:59:18 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.18: +211 -10 lines
Diff to previous 1.18 , to selected 1.21
Added logging capability. Fixed numerous bugs.
Tue Feb 6 16:28:40 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.17: +82 -9 lines
Diff to previous 1.17 , to selected 1.21
Added logging.
Thu Jan 25 02:41:12 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.16: +0 -40 lines
Diff to previous 1.16 , to selected 1.21
Removed support for full-text attribute search.
Wed Jan 24 09:50:29 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.15: +61 -5 lines
Diff to previous 1.15 , to selected 1.21
Fixed an error in the attribute erase method.
Tue Jan 9 01:49:08 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.14: +174 -50 lines
Diff to previous 1.14 , to selected 1.21
Added support for the new text search index for attributes.
Wed Dec 20 20:04:23 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.13: +15 -2 lines
Diff to previous 1.13 , to selected 1.21
Added the ability to specify a regular expression for a value pattern in GetAttributes.
Fri Dec 15 08:16:17 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.12: +133 -1 lines
Diff to previous 1.12 , to selected 1.21
Added ability to backup and restore keys as well as values.
Fri Dec 15 03:24:59 2006 UTC (12 years, 11 months ago) by parrello
Diff to previous 1.11 , to selected 1.21
Converted to a new approach.
Wed Nov 29 20:28:52 2006 UTC (13 years ago) by parrello
Changes since 1.10: +205 -210 lines
Diff to previous 1.10 , to selected 1.21
Converted to another attribute storage strategy.
Tue Nov 28 01:00:08 2006 UTC (13 years ago) by parrello
Changes since 1.9: +601 -754 lines
Diff to previous 1.9 , to selected 1.21
Converted to the new attribute system.
Thu Nov 16 22:09:33 2006 UTC (13 years ago) by parrello
Changes since 1.8: +34 -3 lines
Diff to previous 1.8 , to selected 1.21
Fixed a bug in EraseAttribute, added a get-keys method.
Wed Nov 15 22:34:26 2006 UTC (13 years ago) by parrello
Changes since 1.7: +13 -2 lines
Diff to previous 1.7 , to selected 1.21
Fixed to create the table if an attribute experiences a major change (i.e. is new or gets a new type).
Wed Nov 15 12:04:05 2006 UTC (13 years ago) by parrello
Changes since 1.6: +58 -6 lines
Diff to previous 1.6 , to selected 1.21
Added support for erasing all values of an attribute.
Fri Nov 10 21:59:34 2006 UTC (13 years ago) by parrello
Changes since 1.5: +37 -2 lines
Diff to previous 1.5 , to selected 1.21
Fri Nov 10 21:20:37 2006 UTC (13 years ago) by parrello
Diff to previous 1.4 , to selected 1.21
Fixed a bug with the wild card testing.
Fri Nov 10 21:00:14 2006 UTC (13 years ago) by parrello
Changes since 1.3: +76 -170 lines
Diff to previous 1.3 , to selected 1.21
Fixed so an empty string works as an alternative to undef.
Thu Nov 9 21:19:53 2006 UTC (13 years ago) by parrello
Changes since 1.2: +717 -27 lines
Diff to previous 1.2 , to selected 1.21
Added methods to support the current FIG attribute functions and to migrate attributes from the old system to the new.
Fri Nov 3 16:50:04 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.1: +17 -2 lines
Diff to previous 1.1 , to selected 1.21
Enhanced to automatically index each attribute.
Fri Nov 3 00:32:05 2006 UTC (13 years, 1 month ago) by parrello
Diff to selected 1.21
Added to enable manipulation of the custom attributes database.
