[Bio] / Sprout / CustomAttributes.pm Repository:
Diff of /Sprout/CustomAttributes.pm
revision 1.41, Fri Jan 23 13:44:51 2009 UTC revision 1.42, Thu Feb 5 06:48:05 2009 UTC
# Line 339  Line 339
339
340  =over 4  =over 4
341
342    =item noAnalyze
343
344    Do not analyze the table after loading.
345
346  =item mode  =item mode
347
348  Loading mode. Legal values are C<low_priority> (which reduces the task priority  Loading mode. Legal values are C<low_priority> (which reduces the task priority
# Line 578  Line 582
582              }              }
583              # Regardless of whether additional loading was required, we need to              # Regardless of whether additional loading was required, we need to
584              # analyze the table for performance.              # analyze the table for performance.
585                if (! $options{noAnalyze}) {
586              my $startTime = time();              my $startTime = time();
587              $self->Analyze($tableName);              $self->Analyze($tableName);
588              $retVal->Add(analyzeTime => time() - $startTime);              $retVal->Add(analyzeTime => time() - $startTime);
589          }          }
590            }
591          Trace("Attribute load successful.") if T(2);          Trace("Attribute load successful.") if T(2);
592      };      };
593      # Check for an error.      # Check for an error.
Legend:
Removed from v.1.41
changed lines
  Added in v.1.42
