[Bio] / Sprout / CustomAttributes.pm Repository:
View of /Sprout/CustomAttributes.pm
Revision 1.10 - (download) (as text) (annotate)
Tue Nov 28 01:00:08 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.9: +601 -754 lines
Converted to the new attribute system.
#!/usr/bin/perl -w
package CustomAttributes;
    require Exporter;
    use ERDB;
    @ISA = qw(ERDB);
    use strict;
    use Tracer;
    use ERDBLoad;
=head1 Custom SEED Attribute Manager
=head2 Introduction
The Custom SEED Attributes Manager allows the user to upload and retrieve
custom data for SEED objects. It uses the B<ERDB> database system to
store the attributes.
Attributes are organized by I<attribute key>. Attribute values are
assigned to I<objects>. In the real world, objects have types and IDs;
however, to the attribute database only the ID matters. This will create
a problem if we have a single ID that applies to two objects of different
types, but it is more consistent with the original attribute implementation
in the SEED (which this implementation replaces.
An I<assignment> relates a specific attribute key to a specific object.
Each assignment contains one or more values.
The full suite of ERDB retrieval capabilities is provided. In addition,
custom methods are provided specific to this application. To get all
the values of the attribute C<essential> in a specified B<Feature>, you
would code
    my @values = $attrDB->GetAttributes($fid, 'essential');
where I<$fid> contains the ID of the desired feature.
New attribute keys must be defined before they can be used. A web interface
is provided for this purpose.
=head2 FIG_Config Parameters
The following configuration parameters are used to manage custom attributes.
=over 4
=item attrDbms
Type of database manager used: C<mysql> for MySQL or C<pg> for PostGres.
=item attrDbName
Name of the attribute database.
=item attrHost
Name of the host server for the database. If omitted, the current host
is used.
=item attrUser
User name for logging in to the database.
=item attrPass
Password for logging in to the database.
=item attrPort
TCP/IP port for accessing the database.
=item attrSock
Socket name used to access the database. If omitted, the default socket
will be used.
=item attrDBD
Fully-qualified file name for the database definition XML file. This file
functions as data to the attribute management process, so if the data is
moved, this file must go with it.
=back
=head2 Public Methods
=head3 new
C<< my $attrDB = CustomAttributes->new($splitter); >>
Construct a new CustomAttributes object.
=over 4
=item splitter
Value to be used to split attribute values into sections in the
L</Fig Replacement Methods>. The default is a double colon C<::>.
If you do not use the replacement methods, you do not need to
worry about this parameter.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $splitter) = @_;
    # Connect to the database.
    my $dbh = DBKernel->new($FIG_Config::attrDbms, $FIG_Config::attrDbName,
                            $FIG_Config::attrUser, $FIG_Config::attrPass,
                            $FIG_Config::attrPort, $FIG_Config::attrHost,
                            $FIG_Config::attrSock);
    # Create the ERDB object.
    my $xmlFileName = $FIG_Config::attrDBD;
    my $retVal = ERDB::new($class, $dbh, $xmlFileName);
    # Store the splitter value.
    $retVal->{splitter} = (defined($splitter) ? $splitter : '::');
    # Return the result.
    return $retVal;
=head3 AssignmentKey
C<< my $hashedValue = $attrDB->AssignmentKey($id, $keyName); >>
Return the hashed key used in the assignment table for the specified object ID and
key name.
=over 4
=item id
ID of the object relevant to the assignment.
=item keyName
Name of the key being assigned values.
=item RETURN
Returns the ID that would be used for an B<Assignment> instance representing this
key/id pair.
=back
=cut
sub AssignmentKey {
    my ($self, $id, $keyName) = @_;
    # Compute the result.
    my $retVal = $self->DigestKey("$keyName=$id");
    return $retVal;
=head3 GetAssignment
C<< my $assign = $attrDB->GetAssignment($id, $keyName); >>
Check for an assignment between the specified attribute key and the specified object ID.
If an assignment exists, a B<DBObject> for it will be returned. If it does not exist, an
undefined value will be returned.
=over 4
=item id
=item keyName
Attribute key name for the attribute to which the assignment is to be made.
=item RETURN
Returns a B<DBObject> for the indicated assignment, or C<undef> if the assignment
does not exist.
=back
=cut
sub GetAssignment {
    # Compute the assignment key.
    my $hashKey = $self->AssignmentKey($id, $keyName);
    # Check for an assignment.
    my $retVal = $self->GetEntity('Assignment', $hashKey);
    return $retVal;
=head3 StoreAttributeKey
C<< $attrDB->StoreAttributeKey($attributeName, $type, $notes, \@groups); >>
Create or update an attribute for the database.
=over 4
=item attributeName
Name of the attribute. It must be a valid ERDB field name, consisting entirely of
letters, digits, and hyphens, with a letter at the beginning. If it does not
exist already, it will be created.
=item type
Data type of the attribute. This must be a valid ERDB data type name.
=item notes
Descriptive notes about the attribute. It is presumed to be raw text, not HTML.
=item groups
Reference to a list of the groups to which the attribute should be associated.
This will replace any groups to which the attribute is currently attached.
=back
=cut
sub StoreAttributeKey {
    my ($self, $attributeName, $type, $notes, $groups) = @_;
    my $retVal;
    # Get the data type hash.
    my %types = ERDB::GetDataTypes();
    # Validate the initial input values.
    if (! ERDB::ValidateFieldName($attributeName)) {
        Confess("Invalid attribute name \"$attributeName\" specified.");
    } elsif (! $notes || length($notes) < 25) {
        Confess("Missing or incomplete description for $attributeName.");
    } elsif (! exists $types{$type}) {
        Confess("Invalid data type \"$type\" for $attributeName.");
    } else {
        # Okay, we're ready to begin. See if this key exists.
        my $attribute = $self->GetEntity('AttributeKey', $attributeName);
        if (defined($attribute)) {
            # It does, so we do an update.
            $self->UpdateEntity('AttributeKey', $attributeName,
                                { description => $notes, 'data-type' => $type });
            # Detach the key from its current groups.
            $self->Disconnect('IsInGroup', 'AttributeKey', $attributeName);
        } else {
            # It doesn't, so we do an insert.
            $self->InsertObject('AttributeKey', { id => $attributeName,
        # Attach the key to the specified groups. (We presume the groups already
        # exist.)
        for my $group (@{$groups}) {
            $self->InsertObject('IsInGroup', { 'from-link' => $attributeName,
                                               'to-link'   => $group });
=head3 LoadAttributeKey
C<< my $stats = $attrDB->LoadAttributeKey($keyName, $fh, $keyCol, $dataCol, %options); >>
Load the specified attribute from the specified file. The file should be a
tab-delimited file with internal tab and new-line characters escaped. This is
the typical TBL-style file used by most FIG applications. One of the columns
in the input file must contain the appropriate object id value and the other the
corresponding attribute value.
=over 4
=item keyName
Key of the attribute to load.
=item fh
Open file handle for the input file.
=item idCol
Index (0-based) of the column containing the ID field. The ID field should
contain the ID of an instance of the named entity.
=item dataCol
Index (0-based) of the column containing the data value field.
=item options
Hash specifying the options for this load.
=item RETURN
Returns a statistics object for the load process.
=back
The available options are as follows.
=over 4
=item erase
If TRUE, the key's values will all be erased before loading. (Doing so
makes for a faster load.)
=back
=cut
sub LoadAttributeKey {
    my ($self, $keyName, $fh, $idCol, $dataCol, %options) = @_;
    # Create the return variable.
    my $retVal = Stats->new("lineIn", "shortLine", "lineUsed");
    # Compute the minimum number of fields required in each input line.
    my $minCols = ($idCol < $dataCol ? $idCol : $idCol) + 1;
    # Insure the attribute key exists.
    my $found = $self->GetEntity('AttributeKey', $keyName);
    if (! defined $found) {
        Confess("Attribute key \"$keyName\" not found in database.");
    } else {
        # We need three load files: one for "IsKeyOf", one for "Assignment", and
        # one for "AssignmentValue".
        my $isKeyOfFileName = "$FIG_Config::temp/IsKeyOf$$.dtx";
        my $isKeyOfH = Open(undef, ">$isKeyOfFileName");
        my $assignmentFileName = "$FIG_Config::temp/Assignment.dtx";
        my $assignmentH = Open(undef, ">$assignmentFileName");
        my $assignmentValueFileName = "$FIG_Config::temp/Assignment.dtx";
        my $assignmentValueH = Open(undef, ">$assignmentValueFileName");
        # We also need a hash to track the assignments we find.
        my %assignHash = ();
        # Find out if we intend to erase the key before loading.
        my $erasing = $options{erase} || 0;
        # Loop through the input file.
        while (! eof $fh) {
            # Get the next line of the file.
            my @fields = Tracer::GetLine($fh);
            $retVal->Add(lineIn => 1);
            # Now we need to validate the line.
            if (scalar(@fields) < $minCols) {
                $retVal->Add(shortLine => 1);
            } else {
                # It's valid, so get the ID and value.
                my ($id, $value) = ($fields[$idCol], $fields[$dataCol]);
                # Denote we're using this input line.
                $retVal->Add(lineUsed => 1);
                # Now the fun begins. Find out if we need an assignment for this object ID.
                my $assignKey = "$keyName=$id";
                my $assignValue = $assignHash{$assignKey};
                if (! defined $assignValue) {
                    # Here we have a new assignment. If we are using an erased key,
                    # we will create an assignment object for it. Otherwise, we have
                    # to check the database. First, we get the digested value.
                    $assignValue = $self->AssignmentKey($id, $keyName);
                    # If we're erasing, we always need to create an assignment, but if
                    # we're not erasing we need to check the keys.
                    if ($erasing || ! $self->Exists('Assignment', $assignValue)) {
                        # Here we need to create the assignment.
                        Tracer::PutLine($assignmentH, [$assignValue, $id]);
                        Tracer::PutLine($isKeyOfH, [$keyName, $assignValue]);
                        # Save the assignment key in the hash.
                        $assignHash{$assignKey} = $assignValue;
                        # Update the counter.
                        $retVal->Add(newAssignment => 1);
                # Now we have the assignment ID, so we can attach the new value to the
                # assignment.
                Tracer::PutLine($assignmentValueH, [$assignValue, $value]);
        # Close all the files.
        close $assignmentH;
        close $assignmentValueH;
        close $isKeyOfH;
        # If we are erasing, erase the old key values.
        if ($erasing) {
            $self->EraseAttribute($keyName);
        # If there are new assignments, load them.
        if ($retVal->Ask("newAssignment") > 0) {
            my $ikoStats = $self->LoadTable($isKeyOfFileName, "IsKeyOf", 0);
            $retVal->Accumulate($ikoStats);
            my $aStats = $self->LoadTable($assignmentFileName, "Assignment", 0);
            $retVal->Accumulate($aStats);
        # Finally, load the values.
        my $avStats = $self->LoadTable($assignmentValueFileName, "AssignmentValue", 0);
        $retVal->Accumulate($avStats);
    # Return the statistics.
    return $retVal;
=head3 DeleteAttributeKey
C<< my $stats = $attrDB->DeleteAttributeKey($attributeName); >>
Delete an attribute from the custom attributes database.
=over 4
=item attributeName
Name of the attribute to delete.
=item RETURN
Returns a statistics object describing the effects of the deletion.
=back
=cut
sub DeleteAttributeKey {
    my ($self, $attributeName) = @_;
    # Delete the attribute key.
    my $retVal = $self->Delete('AttributeKey', $attributeName);
    return $retVal;
=head3 NewName
C<< my $text = CustomAttributes::NewName(); >>
Return the string used to indicate the user wants to add a new attribute.
=cut
sub NewName {
    return "(new)";
=head3 ControlForm
C<< my $formHtml = $attrDB->ControlForm($cgi, $name, \%keys); >>
Return a form that can be used to control the creation and modification of
attributes. Only a subset of the attribute keys will be displayed, as
determined by the incoming list.
=over 4
=item cgi
CGI query object used to create HTML.
=item name
Name to give to the form. This should be unique for the web page.
=item keys
Reference to a hash mapping attribute keys to n-tuples. Each tuple will contain the
attribute's data type, its description, and a list of the groups in which it participates.
=item RETURN
Returns the HTML for a form that can be used to  submit instructions to the C<Attributes.cgi> script
for loading, creating, displaying, changing, or deleting an attribute. Note that only the form
controls are generated. The form tags are left to the caller.
=back
=cut
sub ControlForm {
    my ($self, $cgi, $name, $keys) = @_;
    # Declare the return list.
    my @retVal = ();
    # We'll put the controls in a table. Nothing else ever seems to look nice.
    push @retVal, $cgi->start_table({ border => 2, cellpadding => 2 });
    # The first row is for selecting the field name.
    push @retVal, $cgi->Tr($cgi->th("Select a Field"),
                           $cgi->td($self->FieldMenu($cgi, 10, 'fieldName', $keys,
                                                     new => 1,
                                                     notes => "document.$name.notes.value",
                                                     type => "document.$name.dataType.value",
                                                     groups => "document.$name.groups")));
    # Now we set up a dropdown for the data types. The values will be the
    # data type names, and the labels will be the descriptions.
    my %labelMap = map { $_ => $types{$_}->{notes} } keys %types;
    my $typeMenu = $cgi->popup_menu(-name   => 'dataType',
                                    -values => [sort keys %types],
                                    -labels => \%labelMap,
                                    -default => 'string');
    # Allow the user to specify a new field name. This is required if the
    # user has selected the "(new)" marker. We put a little scriptlet in here that
    # selects the (new) marker when the user enters the field.
    push @retVal, "<script language=\"javaScript\">";
    my $fieldField = "document.$name.fieldName";
    my $newName = "\"" . NewName() . "\"";
    push @retVal, $cgi->Tr($cgi->th("New Field Name"),
                           $cgi->td($cgi->textfield(-name => 'newName',
                                                    -size => 30,
                                                    -value => "",
                                                    -onFocus => "setIfEmpty($fieldField, $newName);")),
    push @retVal, $cgi->Tr($cgi->th("Data type"),
                           $cgi->td($typeMenu));
    # The next row is for the notes.
    push @retVal, $cgi->Tr($cgi->th("Description"),
                           $cgi->td($cgi->textarea(-name => 'notes',
                                                   -rows => 6,
                                                   -columns => 80))
    # Now we have the groups, which are implemented as a checkbox group.
    my @groups = $self->GetGroups();
    push @retVal, $cgi->Tr($cgi->th("Groups"),
                           $cgi->td($cgi->checkbox_group(-name=>'groups',
                                    -values=> \@groups))
    # If the user wants to upload new values for the field, then we have
    # an upload file name and column indicators.
    push @retVal, $cgi->Tr($cgi->th("Upload Values"),
                           $cgi->td($cgi->filefield(-name => 'newValueFile',
                                                    -size => 20) .
                                    " Key&nbsp;" .
                                    $cgi->textfield(-name => 'keyCol',
                                                    -size => 3,
                                                    -default => 0) .
                                    " Value&nbsp;" .
                                    $cgi->textfield(-name => 'valueCol',
                                                    -size => 3,
                                                    -default => 1)
    # Now the three buttons: STORE, SHOW, and DELETE.
    push @retVal, $cgi->Tr($cgi->th("&nbsp;"),
                           $cgi->td({align => 'center'},
                                    $cgi->submit(-name => 'Delete', -value => 'DELETE') . " " .
                                    $cgi->submit(-name => 'Store',  -value => 'STORE') . " " .
                                    $cgi->submit(-name => 'Show',   -value => 'SHOW')
    # Close the table and the form.
    push @retVal, $cgi->end_table();
    # Return the assembled HTML.
    return join("\n", @retVal, "");
=head3 FieldMenu
C<< my $menuHtml = $attrDB->FieldMenu($cgi, $height, $name, $keys, %options); >>
Return the HTML for a menu to select an attribute field. The menu will
be a standard SELECT/OPTION thing which is called "popup menu" in the
CGI package, but actually looks like a list. The list will contain
one selectable row per field.
=over 4
=item cgi
CGI query object used to generate HTML.
=item height
Number of lines to display in the list.
=item name
Name to give to the menu. This is the name under which the value will
appear when the form is submitted.
=item keys
Reference to a hash mapping each attribute key name to a list reference,
the list itself consisting of the attribute data type, its description,
and a list of its groups.
=item options
Hash containing options that modify the generation of the menu.
=item RETURN
Returns the HTML to create a form field that can be used to select an
attribute from the custom attributes system.
=back
The permissible options are as follows.
=over 4
=item new
If TRUE, then extra rows will be provided to allow the user to select
a new attribute. In other words, the user can select an existing
attribute, or can choose a C<(new)> marker to indicate a field to
be created in the parent entity.
=item notes
If specified, the name of a variable for displaying the notes attached
to the field. This must be in Javascript form ready for assignment.
So, for example, if you have a variable called C<notes> that
represents a paragraph element, you should code C<notes.innerHTML>.
If it actually represents a form field you should code C<notes.value>.
If an C<innerHTML> coding is used, the text will be HTML-escaped before
it is copied in. Specifying this parameter generates Javascript for
displaying the field description when a field is selected.
=item type
If specified, the name of a variable for displaying the field's
data type. Data types are a much more controlled vocabulary than
notes, so there is no worry about HTML translation. Instead, the
raw value is put into the specified variable. Otherwise, the same
rules apply to this value that apply to I<$noteControl>.
=item groups
If specified, the name of a multiple-selection list control (also called
a popup menu) which shall be used to display the selected groups.
=back
=cut
sub FieldMenu {
    my ($self, $cgi, $height, $name, $keys, %options) = @_;
    # Reformat the list of keys.
    my %keys = %{$keys};
    # Add the (new) key, if needed.
    if ($options{new}) {
        $keys{NewName()} = ["string", ""];
    # Get a sorted list of key.
    my @keys = sort keys %keys;
    # We need to create the name for the onChange function. This function
    # may not do anything, but we need to know the name to generate the HTML
    # for the menu.
    my $changeName = "${name}_setNotes";
    my $retVal = $cgi->popup_menu({name => $name,
                                   size => $height,
                                   onChange => "$changeName(this.value)",
                                   values => \@keys,
    # Create the change function.
    $retVal .= "\n<script language=\"javascript\">\n";
    $retVal .= "    function $changeName(fieldValue) {\n";
    # The function only has a body if we have a control to store data about the
    # attribute.
    if ($options{notes} || $options{type} || $options{groups}) {
        # Check to see if we're storing HTML or text into the note control.
        my $noteControl = $options{notes};
        my $htmlMode = ($noteControl && $noteControl =~ /innerHTML$/);
        # We use a CASE statement based on the newly-selected field value. The
        # field description will be stored in the JavaScript variable "myText"
        # and the data type in "myType". Note the default data type is a normal
        # string, but the default notes is an empty string.
        $retVal .= "        var myText = \"\";\n";
        $retVal .= "        var myType = \"string\";\n";
        $retVal .= "        switch (fieldValue) {\n";
        # Loop through the keys.
        for my $key (@keys) {
            # Generate this case.
            $retVal .= "        case \"$key\" :\n";
            # Here we either want to update the note display, the
            # type display, the group list, or a combination of them.
            my ($type, $notes, @groups) = @{$keys{$key}};
            if ($noteControl) {
                # Insure it's in the proper form.
                if ($htmlMode) {
                    $notes = ERDB::HTMLNote($notes);
                # Escape it for use as a string literal.
                $notes =~ s/\n/\\n/g;
                $notes =~ s/"/\\"/g;
                $retVal .= "           myText = \"$notes\";\n";
            if ($options{type}) {
                # Here we want the type updated.
                $retVal .= "           myType = \"$type\";\n";
            if ($options{groups}) {
                # Here we want the groups shown. Get a list of this attribute's groups.
                # We'll search through this list for each group to see if it belongs with
                # our attribute.
                my $groupLiteral = "=" . join("=", @groups) . "=";
                # Now we need some variables containing useful code for the javascript. It's
                # worth knowing we go through a bit of pain to insure $groupField[i] isn't
                # parsed as an array element.
                my $groupField = $options{groups};
                my $currentField = $groupField . "[i]";
                # Do the javascript.
                $retVal .= "           var groupList = \"$groupLiteral\";\n";
                $retVal .= "           for (var i = 0; i < $groupField.length; i++) {\n";
                $retVal .= "              var srchString = \"=\" + $currentField.value + \"=\";\n";
                $retVal .= "              var srchLoc = groupList.indexOf(srchString);\n";
                $retVal .= "              $currentField.checked = (srchLoc >= 0);\n";
                $retVal .= "           }\n";
            # Close this case.
            $retVal .= "           break;\n";
        # Close the CASE statement and make the appropriate assignments.
        $retVal .= "        }\n";
        if ($noteControl) {
            $retVal .= "        $noteControl = myText;\n";
            $retVal .= "        $options{type} = myType;\n";
    # Terminate the change function.
    $retVal .= "    }\n";
    $retVal .= "</script>\n";
    return $retVal;
=head3 GetGroups
C<< my @groups = $attrDB->GetGroups(); >>
Return a list of the available groups.
=cut
sub GetGroups {
    my ($self) = @_;
    # Get the groups.
    my @retVal = $self->GetFlat(['AttributeGroup'], "", [], 'AttributeGroup(id)');
    # Return them.
    return @retVal;
=head3 GetAttributeData
C<< my %keys = $attrDB->GetAttributeData($type, @list); >>
Return attribute data for the selected attributes. The attribute
data is a hash mapping each attribute key name to a n-tuple containing the
data type, the description, and the groups. This is the same format expected in
the L</FieldMenu> and L</ControlForm> methods for the list of attributes to display.
=over 4
=item type
Type of attribute criterion: C<name> for attributes whose names begin with the
specified string, or C<group> for attributes in the specified group.
=item list
List containing the names of the groups or keys for the desired attributes.
=item RETURN
Returns a hash mapping each attribute key name to its data type, description, and
parent groups.
=back
=cut
sub GetAttributeData {
    my ($self, $type, @list) = @_;
    # Set up a hash to store the attribute data.
    my %retVal = ();
    # Loop through the list items.
    for my $item (@list) {
        # Set up a query for the desired attributes.
        my $query;
        if ($type eq 'name') {
            # Here we're doing a generic name search. We need to escape it and then tack
            # on a %.
            my $parm = $item;
            $parm =~ s/_/\\_/g;
            $parm =~ s/%/\\%/g;
            $parm .= "%";
            # Ask for matching attributes. (Note that if the user passed in a null string
            # he'll get everything.)
            $query = $self->Get(['AttributeKey'], "AttributeKey(id) LIKE ?", [$parm]);
        } elsif ($type eq 'group') {
            $query = $self->Get(['IsInGroup', 'AttributeKey'], "IsInGroup(to-link) = ?", [$item]);
        } else {
            Confess("Unknown attribute query type \"$type\".");
        while (my $row = $query->Fetch()) {
            # Get this attribute's data.
            my ($key, $type, $notes) = $row->Values(['AttributeKey(id)', 'AttributeKey(data-type)',
                                                     'AttributeKey(description)']);
            # If it's new, get its groups and add it to the return hash.
            if (! exists $retVal{$key}) {
                my @groups = $self->GetFlat(['IsInGroup'], "IsInGroup(from-link) = ?",
                                            [$key], 'IsInGroup(to-link)');
                $retVal{$key} = [$type, $notes, @groups];
    return %retVal;
=head2 FIG Method Replacements
The following methods are used by B<FIG.pm> to replace the previous attribute functionality.
Some of the old functionality is no longer present: controlled vocabulary is no longer
supported and there is no longer any searching by URL. Fortunately, neither of these
capabilities were used in the old system.
The methods here are the only ones supported by the B<RemoteCustomAttributes> object.
The idea is that these methods represent attribute manipulation allowed by all users, while
the others are only for privileged users with access to the attribute server.
In the previous implementation, an attribute had a value and a URL. In the new implementation,
there is only a value. In this implementation, each attribute has only a value. These
methods will treat the value as a list with the individual elements separated by the
value of the splitter parameter on the constructor (L</new>). The default is double
colons C<::>.
So, for example, an old-style keyword with a value of C<essential> and a URL of
C<http://www.sciencemag.org/cgi/content/abstract/293/5538/2266> using the default
splitter value would be stored as
    essential::http://www.sciencemag.org/cgi/content/abstract/293/5538/2266
The best performance is achieved by searching for a particular key for a specified
feature or genome.
=head3 GetAttributes
C<< my @attributeList = $attrDB->GetAttributes($objectID, $key, @values); >>
In the database, attribute values are sectioned into pieces using a splitter
value specified in the constructor (L</new>). This is not a requirement of
the attribute system as a whole, merely a convenience for the purpose of
these methods. If a value has multiple sections, each section
is matched against the corresponding criterion in the I<@valuePatterns> list.
This method returns a series of tuples that match the specified criteria. Each tuple
will contain an object ID, a key, and one or more values. The parameters to this
method therefore correspond structurally to the values expected in each tuple. In
addition, you can ask for a generic search by suffixing a percent sign (C<%>) to any
of the parameters. So, for example,
    my @attributeList = $attrDB->GetAttributes('fig|100226.1.peg.1004', 'structure%', 1, 2);
would return something like
    ['fig}100226.1.peg.1004', 'structure', 1, 2]
    ['fig}100226.1.peg.1004', 'structure1', 1, 2]
    ['fig}100226.1.peg.1004', 'structure2', 1, 2]
    ['fig}100226.1.peg.1004', 'structureA', 1, 2]
Use of C<undef> in any position acts as a wild card (all values). You can also specify
a list reference in the ID column. Thus,
    my @attributeList = $attrDB->GetAttributes(['100226.1', 'fig|100226.1.%'], 'PUBMED');
would get the PUBMED attribute data for Streptomyces coelicolor A3(2) and all its
features.
In addition to values in multiple sections, a single attribute key can have multiple
values, so even
    my @attributeList = $attrDB->GetAttributes($peg, 'virulent');
which has no wildcard in the key or the object ID, may return multiple tuples.
Value matching in this system works very poorly, because of the way multiple values are
stored. For the object ID and key name, we create queries that filter for the desired
results. For the values, we do a comparison after the attributes are retrieved from the
database. As a result, queries in which filter only on value end up reading the entire
attribute table to find the desired results.
=over 4
=item objectID
ID of object whose attributes are desired. If the attributes are desired for multiple
objects, this parameter can be specified as a list reference. If the attributes are
desired for all objects, specify C<undef> or an empty string. Finally, you can specify
attributes for a range of object IDs by putting a percent sign (C<%>) at the end.
=item key
Attribute key name. A value of C<undef> or an empty string will match all
attribute keys. If the values are desired for multiple keys, this parameter can be
specified as a list reference. Finally, you can specify attributes for a range of
keys by putting a percent sign (C<%>) at the end.
=item values
List of the desired attribute values, section by section. If C<undef>
or an empty string is specified, all values in that section will match. A
generic match can be requested by placing a percent sign (C<%>) at the end.
In that case, all values that match up to and not including the percent sign
will match.
=item RETURN
Returns a list of tuples. The first element in the tuple is an object ID, the
second is an attribute key, and the remaining elements are the sections of
the attribute value. All of the tuples will match the criteria set forth in
the parameter list.
=back
=cut
sub GetAttributes {
    my ($self, $objectID, $key, @values) = @_;
    # We will create one big honking query. The following hash will build the filter
    # clause and a parameter list.
    my %data = ('IsKeyOf(from-link)' => $key, 'Assignment(object-id)' => $objectID);
    my @filter = ();
    my @parms = ();
    # This next loop goes through the different fields that can be specified in the
    # parameter list and generates filters for each.
    for my $field (keys %data) {
        # Accumulate filter information for this field. We will OR together all the
        # elements accumulated to create the final result.
        my @fieldFilter = ();
        # Get the specified data from the caller.
        my $fieldPattern = $data{$field};
        # Only proceed if the pattern is one that won't match everything.
        if (defined($fieldPattern) && $fieldPattern ne "" && $fieldPattern ne "%") {
            # Convert the pattern to an array.
            my @patterns = ();
            if (ref $fieldPattern eq 'ARRAY') {
                push @patterns, @{$fieldPattern};
            } else {
                push @patterns, $fieldPattern;
            # Only proceed if the array is nonempty. The loop will work fine if the
            # array is empty, but when we build the filter string at the end we'll
            # get "()" in the filter list, which will result in an SQL syntax error.
            if (@patterns) {
                # Loop through the individual patterns.
                for my $pattern (@patterns) {
                    # Check for a generic request.
                    if (substr($pattern, -1, 1) ne '%') {
                        # Here we have a normal request.
                        push @fieldFilter, "$field = ?";
                        push @parms, $pattern;
                    } else {
                        # Here we have a generate request, so we will use the LIKE operator to
                        # filter the field to this value pattern.
                        push @fieldFilter, "$field LIKE ?";
                        # We must convert the pattern value to an SQL match pattern. First
                        # we chop off the percent sign. (Note that I eschew chop because I
                        # want a copy of the string.
                        my $actualPattern = substr($pattern, 0, -1);
                        # Now we escape the underscores. Underscores are an SQL wild card
                        # character, but they are used frequently in key names and object IDs.
                        $actualPattern = s/_/\\_/g;
                        # Add the escaped pattern to the bound parameter list.
                        push @parms, $actualPattern;
                # Form the filter for this field.
                my $fieldFilterString = join(" OR ", @fieldFilter);
                push @filter, "($fieldFilterString)";
    # Now @filter contains one or more filter strings and @parms contains the parameter
    # values to bind to them.
    my $actualFilter = join(" AND ", @filter);
    my @retVal = ();
    # Get the number of value sections we have to match.
    my $sectionCount = scalar(@values);
    # Now we're ready to make our query.
    my $query = $self->Get(['IsKeyOf', 'Assignment'], $actualFilter, \@parms);
    # Loop through the assignments found.
        # Get the current row's data.
        my ($id, $key, @valueStrings) = $row->Values(['Assignment(object-id)', 'IsKeyOf(from-link)',
                                                      'Assignment(value)']);
        # Process each value string individually.
        for my $valueString (@valueStrings) {
            # Break the value into sections.
            my @sections = split($self->{splitter}, $valueString);
            # Match each section against the incoming values. We'll assume we're
            # okay unless we learn otherwise.
            my $matching = 1;
            for (my $i = 0; $i < $sectionCount && $matching; $i++) {
                # We need to check to see if this section is generic.
                if (substr($values[$i], -1, 1) eq '%') {
                    my $matchLen = length($values[$i] - 1);
                    $matching = substr($sections[$i], 0, $matchLen) eq
                                substr($values[$i], 0, $matchLen);
                } else {
                    $matching = ($sections[$i] eq $values[$i]);
            # If we match, output this row to the return list.
            if ($matching) {
                push @retVal, [$id, $key, @sections];
    # Return the rows found.
    return @retVal;
=head3 AddAttribute
C<< $attrDB->AddAttribute($objectID, $key, @values); >>
Add an attribute key/value pair to an object. This method cannot add a new key, merely
add a value to an existing key. Use L</StoreAttributeKey> to create a new key.
=over 4
=item objectID
ID of the object to which the attribute is to be added.
=item key
Attribute key name.
=item values
One or more values to be associated with the key. The values are joined together with
the splitter value before being stored as field values. This enables L</GetAttributes>
to split them apart during retrieval. The splitter value defaults to double colons C<::>.
=back
=cut
sub AddAttribute {
    # Don't allow undefs.
    if (! defined($objectID)) {
        Confess("No object ID specified for AddAttribute call.");
    } elsif (! defined($key)) {
        Confess("No attribute key specified for AddAttribute call.");
    } elsif (! @values) {
        Confess("No values specified in AddAttribute call for key $key.");
    } else {
        # Okay, now we have some reason to believe we can do this. Get the key for
        # the relevant assignment.
        my $assignKey = $self->AssignmentKey($objectID, $key);
        # Form the values into a scalar.
        my $valueString = join($self->{splitter}, @values);
        # See if the assignment exists.
        my $found = $self->Exists('Assignment', $assignKey);
        if (! $found) {
            # Here we have a new assignment. Insure that the key is valid.
            $found = $self->Exists('AttributeKey', $key);
            if (! $found) {
                Confess("Attribute key \"$key\" not found in database.");
            } else {
                # The key is valid, so we can create a new assignment.
                $self->InsertObject('Assignment', { id => $assignKey,
                                                    'object-id' => $objectID,
                                                    value => [$valueString],
                # Connect the assignment to the key.
                $self->InsertObject('IsKeyOf', { 'from-link' => $key,
                                                 'to-link' => $assignKey,
        } else {
            # An assignment already exists. Add the new value to it.
            $self->InsertValue($assignKey, 'Assignment(value)', $valueString);
    # Return a one, indicating success. We do this for backward compatability.
    return 1;
C<< $attrDB->DeleteAttribute($objectID, $key, @values); >>
Delete the specified attribute key/value combination from the database.
=over 4
=item objectID
ID of the object whose attribute is to be deleted.
=item key
Attribute key name.
=item values
One or more values associated with the key. If no values are specified, then all values
will be deleted. Otherwise, only a matching value will be deleted.
=back
=cut
sub DeleteAttribute {
        Confess("No object ID specified for DeleteAttribute call.");
        Confess("No attribute key specified for DeleteAttribute call.");
    } else {
        # Get the assignment key for this object/attribute pair.
        # Only proceed if it exists.
        if ($found && ! @values) {
            # Here the caller wants to delete the entire assignment.
            $self->Delete('Assignment', $assignKey);
        } else {
            # Here we're looking to delete only the one value. First, we get all
            # the values currently present.
            my @currentValues = $self->GetFlat(['Assignment'], "Assignment(id) = ?",
                                               [$assignKey], 'Assignment(value)');
            # Find our value amongst them.
            my @matches = grep { $_ eq $valueString } @currentValues;
            # Only proceed if we found it.
            if (@matches) {
                # Find out if it's the only value.
                if (scalar(@matches) == scalar(@currentValues)) {
                    # It is, so delete the assignment.
                } else {
                    # It's not, so only delete the value itself.
                    $self->DeleteValue('Assignment', $assignKey, 'value', $valueString);
    # Return a one. This is for backward compatability.
    return 1;
=head3 ChangeAttribute
C<< $attrDB->ChangeAttribute($objectID, $key, \@oldValues, \@newValues); >>
Change the value of an attribute key/value pair for an object.
=over 4
=item objectID
ID of the genome or feature to which the attribute is to be changed. In general, an ID that
starts with C<fig|> is treated as a feature ID, and an ID that is all digits and periods
is treated as a genome ID. For IDs of other types, this parameter should be a reference
to a 2-tuple consisting of the entity type name followed by the object ID.
=item key
Attribute key name. This corresponds to the name of a field in the database.
=item oldValues
One or more values identifying the key/value pair to change.
=item newValues
One or more values to be put in place of the old values.
=back
=cut
sub ChangeAttribute {
    my ($self, $objectID, $key, $oldValues, $newValues) = @_;
        Confess("No object ID specified for ChangeAttribute call.");
        Confess("No attribute key specified for ChangeAttribute call.");
    } elsif (! defined($oldValues) || ref $oldValues ne 'ARRAY') {
        Confess("No old values specified in ChangeAttribute call for key $key.");
    } elsif (! defined($newValues) || ref $newValues ne 'ARRAY') {
        Confess("No new values specified in ChangeAttribute call for key $key.");
    } else {
        # We do the change as a delete/add.
        $self->DeleteAttribute($objectID, $key, @{$oldValues});
        $self->AddAttribute($objectID, $key, @{$newValues});
    # Return a one. We do this for backward compatability.
    return 1;
=head3 EraseAttribute
C<< $attrDB->EraseAttribute($entityName, $key); >>
Erase all values for the specified attribute key. This does not remove the
key from the database; it merely removes all the values.
=over 4
=item key
Key to erase.
=back
=cut
sub EraseAttribute {
    my ($self, $key) = @_;
    # Delete everything connected to the key. The "keepRoot" option keeps the key in the
    # datanase while deleting everything attached to it.
    $self->Delete('AttributeKey', $key, keepRoot => 1);
    # Return a 1, for backward compatability.
    return 1;
=head3 GetAttributeKeys
C<< my @keyList = $attrDB->GetAttributeKeys($groupName); >>
Return a list of the attribute keys for a particular group.
=over 4
=item groupName
Name of the group whose keys are desired.
=item RETURN
Returns a list of the attribute keys for the specified group.
=back
=cut
sub GetAttributeKeys {
    my ($self, $groupName) = @_;
    # Get the attributes for the specified group.
    my @groups = $self->GetFlat(['IsInGroup'], "IsInGroup(to-link) = ?", [$groupName],
                                'IsInGroup(from-link)');
    # Return the keys.
    return sort @groups;
1;
