[Bio] / Sprout / CorePegs.pl Repository:
Log of /Sprout/CorePegs.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Thu Feb 14 19:04:15 2008 UTC (12 years, 3 months ago) by parrello
Changes since 1.1: +73 -51 lines
Added the "orgs" parameter to enable specifying all, all NMPDR, or only core genomes.
Wed Feb 6 23:20:20 2008 UTC (12 years, 3 months ago) by parrello
Added to provide feature lists for Andreas.
