[Bio] / Sprout / ContigDNA.pm Repository:
Log of /Sprout/ContigDNA.pm
Revision 1.4
Wed Aug 24 21:11:36 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: HEAD
Changes since 1.3: +0 -0 lines
FILE REMOVED
Updates for putting gc_content in Sapling.
Tue Feb 5 04:50:11 2008 UTC (12 years, 3 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Fixed a POD error.
Thu Dec 6 14:58:03 2007 UTC (12 years, 5 months ago) by parrello
Sat Sep 10 07:40:17 2005 UTC (14 years, 8 months ago) by parrello
Created to enable location testing for contigs not yet in the database.
