[Bio] / Sprout / ContigDNA.pm Repository:
View of /Sprout/ContigDNA.pm
Revision 1.3 - (download) (as text) (annotate)
Tue Feb 5 04:50:11 2008 UTC (12 years ago) by parrello
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2009_05_18, mgrast_dev_03252011, mgrast_release_3_0, rast_rel_2010_1206, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2008_04_23, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, rast_rel_2009_03_26, rast_rel_2008_11_24, rast_rel_2008_08_07
Fixed a POD error.
#!/usr/bin/perl -w
package ContigDNA;
    use strict;
    use Tracer;
    use FIG;
    use Genome;
=head1 Contig DNA manipulation object
=head2 Introduction
This method creates a pseudo-FIG object for use by the B<FullLocation> object. It
supports the L</contig_ln> and L</dna_seq> methods.
Note that it keeps all the data structures in memory, so it should not be used except for
a few genomes with small number of gen
=cut
=head2 Public Methods
=head3 new
    my $cdna = ContigDNA->new($genID1 => $file1, $genID2 => $file, ... $genIDN => $fileN );
Construct a new pseudo-FIG object from a set of FASTA files. The incoming parameters come
in pairs. The first of each pair is the ID of a genome; the second is the name of a FASTA
file containing the contig data.
=over 4
=item genID1, genID2, ... genIDN
IDs of the genomes whose contigs are to be read into memory.
=item file1, file2, ... fileN
Names of the FASTA files containing the genome data.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, %files) = @_;
    # Create the object.
    my $retVal = { };
    # Loop through the genomes.
    for my $genID (keys %files) {
        # Get the name of this genome's FASTA file.
        my $file = $files{$genID};
        # Read it in using the Genome object.
        my $genomeData = Genome->new($genID, $file, "");
        # Put it in the hash.
        $retVal->{$genID} = $genomeData;
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head3 dna_seq
    my $sequence = $sfxlate->dna_seq($genomeID, @locations);
Return the sequence represented by a list of locations. The locations
should be in the standard form I<contigID>C<_>I<begin>I<dir>I<end>.
=over 4
=item genomeID
ID of the relevant genome.
=item location1, location2, ... locationN
List of locations to be included in the DNA sequence.
=item RETURN
Returns a string specifying the DNA nucleotides in the specified locations.
=back
=cut
#: Return Type $;
sub dna_seq {
    my ($self, $genomeID, @locations) = @_;
    # Get the Genome object.
    my $genome = $self->{$genomeID};
    # Start the return string.
    my $retVal = "";
    # Loop through the locations.
    for my $location (@locations) {
        # Get the DNA.
        my $dna = $genome->GetLocation($location);
        # Add it to the return string.
        $retVal .= $dna;
    # Return the result.
    return $retVal;
=head3 contig_ln
    my $length = $sfxlate->contig_ln($genomeID, $contig);
Return the length of the specified contig.
=over 4
=item genomeID
ID of the genome to which the contig belongs.
=item contigID
ID of the contig whose length is desired.
=item RETURN
Returns the length (in base pairs) of the specified contig in the specified
genome.
=back
=cut
#: Return Type $;
sub contig_ln {
    my($self, $genomeID, $contigID) = @_;
    return $genome->ContigLen($contigID);
1;
