[Bio] / Sprout / ContigDNA.pm Repository:
View of /Sprout/ContigDNA.pm
Revision 1.4 - (download) (as text) (annotate)
Wed Aug 24 21:11:36 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: HEAD
Changes since 1.3: +0 -0 lines
FILE REMOVED
Updates for putting gc_content in Sapling.
#!/usr/bin/perl -w
package ContigDNA;
    use strict;
    use Tracer;
    use FIG;
    use Genome;
=head1 Contig DNA manipulation object
=head2 Introduction
This method creates a pseudo-FIG object for use by the B<FullLocation> object. It
supports the L</contig_ln> and L</dna_seq> methods.
Note that it keeps all the data structures in memory, so it should not be used except for
a few genomes with small number of gen
=cut
=head2 Public Methods
=head3 new
    my $cdna = ContigDNA->new($genID1 => $file1, $genID2 => $file, ... $genIDN => $fileN );
Construct a new pseudo-FIG object from a set of FASTA files. The incoming parameters come
in pairs. The first of each pair is the ID of a genome; the second is the name of a FASTA
file containing the contig data.
=over 4
=item genID1, genID2, ... genIDN
IDs of the genomes whose contigs are to be read into memory.
=item file1, file2, ... fileN
Names of the FASTA files containing the genome data.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, %files) = @_;
    # Create the object.
    my $retVal = { };
    # Loop through the genomes.
    for my $genID (keys %files) {
        # Get the name of this genome's FASTA file.
        my $file = $files{$genID};
        # Read it in using the Genome object.
        my $genomeData = Genome->new($genID, $file, "");
        # Put it in the hash.
        $retVal->{$genID} = $genomeData;
    # Bless and return it.
    bless $retVal, $class;
    return $retVal;
=head3 dna_seq
    my $sequence = $sfxlate->dna_seq($genomeID, @locations);
Return the sequence represented by a list of locations. The locations
should be in the standard form I<contigID>C<_>I<begin>I<dir>I<end>.
=over 4
=item genomeID
ID of the relevant genome.
=item location1, location2, ... locationN
List of locations to be included in the DNA sequence.
=item RETURN
Returns a string specifying the DNA nucleotides in the specified locations.
=back
=cut
#: Return Type $;
sub dna_seq {
    my ($self, $genomeID, @locations) = @_;
    # Get the Genome object.
    my $genome = $self->{$genomeID};
    # Start the return string.
    my $retVal = "";
    # Loop through the locations.
    for my $location (@locations) {
        # Get the DNA.
        my $dna = $genome->GetLocation($location);
        # Add it to the return string.
        $retVal .= $dna;
    # Return the result.
    return $retVal;
=head3 contig_ln
    my $length = $sfxlate->contig_ln($genomeID, $contig);
Return the length of the specified contig.
=over 4
=item genomeID
ID of the genome to which the contig belongs.
=item contigID
ID of the contig whose length is desired.
=item RETURN
Returns the length (in base pairs) of the specified contig in the specified
genome.
=back
=cut
#: Return Type $;
sub contig_ln {
    my($self, $genomeID, $contigID) = @_;
    return $genome->ContigLen($contigID);
1;
