Parent Directory
Revision Log
Added as a utility for cleaning out old temp files.
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # use strict; use Tracer; use File::stat; use Stats; =head1 CleanUp Script CleanUp [options] Delete old temporary files =head2 Introduction This is a simple script that deletes old files from the temporary directories used by the NMPDR. =head2 Command-Line Options =over 4 =item trace Specifies the tracing level. The higher the tracing level, the more messages will appear in the trace log. Use E to specify emergency tracing. =item age Minimum file age for deletion, in hours. Files that have not been modified in the specified number of hours will be deleted. =item sandbox Path to the SEED/NMPDR sandbox (FIGdisk) to delete. The default is the current instance. =item user Name suffix to be used for log files. If omitted, the PID is used. =item sql If specified, turns on tracing of SQL activity. =item background Save the standard and error output to files. The files will be created in the FIG temporary directory and will be named C<err>I<User>C<.log> and C<out>I<User>C<.log>, respectively, where I<User> is the value of the B<user> option above. =item help Display this command's parameters and options. =item warn Create an event in the RSS feed when an error occurs. =item phone Phone number to message when the script is complete. =back =cut # Get the command-line options and parameters. my ($options, @parameters) = StandardSetup([qw() ], { trace => [2, "tracing level"], age => [24, "minimum age in hours for files to be deleted"], sandbox => ["$FIG_Config::fig_disk", "sandbox whose temp files are to be deleted"], phone => ["", "phone number (international format) to call when load finishes"] }, "", @ARGV); # Set a variable to contain return type information. my $rtype; # Insure we catch errors. eval { # Create a statistics object. my $stats = Stats->new(qw(deleted directories locked processed bytes)); # Get the specified sandbox. my $root = $options->{sandbox}; if (! -d $root) { Trace("NMPDR/SEED instance \"$root\" not found.") if T(2); } else { # Compute the names of the directories to clean. my @dirs = ("$root/FIG/Tmp", "$root/FIG/WikiData/working/tmp"); # We're going to be doing recursive stuff, so we will treat the directory list # as a stack. while (my $dir = pop @dirs) { # Check for the directory. if (! -d $dir) { # Not found, so just skip it. Trace("Directory \"$dir\" does not exist and will be skipped.") if T(2); } else { # Open it for reading. We don't dare slurp it, because some of these # directories contain millions of files. my $okFlag = opendir(my $dh, $dir); if (! $okFlag) { Trace("Could not open \"$dir\": $!") if T(1); } else { $stats->Add(directories => 1); Trace("Processing $dir.") if T(2); # Loop through the directory files. while (my $fileTitle = readdir $dh) { # Only process if this is not a dot-marked file. if (substr($fileTitle, 0, 1) ne ".") { # Compute the absolute file name. my $fileName = "$dir/$fileTitle"; # Is it a subdirectory? if (-d $fileName) { # Yes, stack it. push @dirs, $fileName; } else { # No, so we have a real file. $stats->Add(processed => 1); my $fileData = stat $fileName; # Check its age. my $age = (time() - $fileData->mtime) / 3600; if ($age >= $options->{age}) { # It's old, so we want to delete it. Get its size # first, so we can track the bytes saved. my $byteSize = $fileData->blksize * $fileData->blocks; eval { $okFlag = unlink($fileName); }; if ($@) { Trace("Error deleting $fileName: $@") if T(3); $stats->Add(locked => 1); } elsif (! $okFlag) { # It failed, so count it as a lock. $stats->Add(locked => 1); } else { # It worked, so count it. $stats->Add(bytes => $byteSize); Trace($stats->Ask('bytes') . " bytes and " . $stats->Ask('deleted') . " files deleted.") if $stats->Check(deleted => 1000) && T(3); } } } } } } } } # We're done. Trace("Cleanup complete:\n" . $stats->Show()) if T(2); } }; if ($@) { Trace("Script failed with error: $@") if T(0); $rtype = "error"; } else { Trace("Script complete.") if T(2); $rtype = "no error"; } if ($options->{phone}) { my $msgID = Tracer::SendSMS($options->{phone}, "CleanUp terminated with $rtype."); if ($msgID) { Trace("Phone message sent with ID $msgID.") if T(2); } else { Trace("Phone message not sent.") if T(2); } } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
