[Bio] / Sprout / CleanUp.pl Repository:
Log of /Sprout/CleanUp.pl
Thu Apr 2 01:33:07 2009 UTC (10 years, 10 months ago) by parrello
Fixed a comment.
Tue Sep 16 19:24:53 2008 UTC (11 years, 5 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Diff to selected 1.2
Added as a utility for cleaning out old temp files.
