[Bio] / Sprout / BioWords.pm Repository:
Log of /Sprout/BioWords.pm
Sat Oct 18 16:20:59 2008 UTC (10 years, 11 months ago) by parrello
Changes since 1.2: +90 -7 lines
Fixed to strip the silent 'e' from the end of a word.
Tue Sep 16 18:37:03 2008 UTC (11 years ago) by parrello
Changes since 1.1: +3 -0 lines
Added tracing.
Tue Sep 9 21:02:10 2008 UTC (11 years ago) by parrello
Changes for v24 database.
