Parent Directory
Revision Log
Added tracing.
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package BioWords; use strict; use Tracer; =head1 BioWords Package Microbiological Word Conflation Helper =head2 Introduction This object is in charge of managing keywords used to search the database. Its purpose is to insure that if a user types something close to the correct word, a usable result will be returned. A keyword string consists of words separated by delimiters. A I<word> is an uninterrupted sequence of letters, semidelimiters (currently only C<'>) and digits. A word that begins with a letter is called a I<real word>. For each real word we produce two alternate forms. The I<stem> represents the root form of the word (e.g. C<skies> to C<ski>, C<following> to C<follow>). The I<phonex> is computed from the stem by removing the vowels and equating consonants that produce similar sounds. It is likely a mispelled word will have the same phonex as its real form. In addition to computing stems and phonexes, this object also I<cleans> a keyword. I<Cleaning> consists of converting upper-case letters to lower case and converting certain delimiters. In particular, bar (C<|>), colon (C<:>), and semi-colon (C<;>) are converted to a single quote (C<'>) and period (C<.>) and hyphen (C<->) are converted to underscore (C<_>). The importance of this is that the single quote and underscore are considered word characters by the search software. The cleaning causes the names of chemical compounds and the IDs of features and genomes to behave as words when searching. Search words must be at least three characters long, so the stem of a real word with only three letters is the word itself, and any real word with only two letters is discarded. In addition, there is a list of I<stop words> that are discarded by the keyword search. These will have an empty string for the stem and phonex. Note that the stemming algorithm differs from the standard for English because of the use of Greek and Latin words in chemical compound names and genome taxonomies. The algorithm has been evolving in response to numerous experiments and is almost certainly not in its last iteration. The fields in this object are as follows. =over 4 =item stems Hash of the stems found so far. This is cleared by L</AnalyzeSearchExpression>, so it can be used by clients to determine the number of search expressions containing a particular stem. =item cache Reference to a hash that maps a pure word to a hash containing its stem, a count of the number of times it has occurred, and its phonex. The hash is also used to keep exceptions (which map to their predetermined stem) and stop words (which map to an empty string). The cache should only be used when the number of words being processed is small. If multiple millions of words are put into the cache, it causes the application to hang. =item stopFile The name of a file containing the stop word list, one word per line. The stop word file is read into the cache the first time we try to stem a pure word. Once the file is read, this field is cleared so that we know it's handled. =item exceptionFile The name of a file containing exception rules, one rule per line. Each rule consists of a space-delimited list of words followed by a single stem. The exception file is read into the cache the first time we try to stem a pure word. Once the file is read, this field is cleared so that we know it's handled. =item cacheFlag TRUE if incoming words should be cached, else FALSE. =item VOWEL The list of vowel characters (lower-case). This defaults to the value of the compile-time constant VOWELS, but may be overridden by the constructor. =item LETTER The list of letter characters (lower-case). This defaults to the value of the compile-time constant LETTERS, but may be overridden by the constructor. All of the vowels should be included in the list of letters. =item DIGIT The list of digit characters (lower-case). This defaults to the value of the compile-time constant DIGITS, but may be overridden by the constructor. =item WORD The list of all word-like characters. This is the union of the letters and digits. =back We allow configuration of letters, digits, and vowels; but in general the stemming and phonex algorithms are aware of the English language and what the various letters mean. The main use of the configuration strings is to allow flexibility in the treatment of special characters, such as underscore (C<_>) and the single quote (C<'>). The defaults have all been chosen fairly carefully based on empirical testing, but of course everything is subject to evolution. =head2 Special Declarations =head3 EMPTY The EMPTY constant simply evaluates to the empty string. It makes the stemming rules more readable. =cut use constant EMPTY => ''; =head3 SHORT The SHORT constant specifies the minimum length for a word. A word shorter than the minimum length is treated as a stop word. =cut use constant SHORT => 3; =head3 VOWELS String containing the characters that are considered vowels (lower case only). =cut use constant VOWELS => q(aeiou_); =head3 LETTERS String containing the characters that are considered letters (lower case only). =cut use constant LETTERS => q(abcdefghijklmnopqrstuvwxyz_); =head3 DIGITS String containing the characters that are considered digits (lower case only). =cut use constant DIGITS => q(0123456789'); =head3 new my $bw = BioWords->new(%options); Construct a new BioWords object. The following options are supported. =over 4 =item exceptions Name of the exception file, or a reference to a hash containing the exception rules. The default is to have no exceptions. =item stops Name of the stop word file, or a reference to a list containing the stop words. The default is to have no stop words. =item vowels List of characters to be treated as vowels (lower-case only). The default is a compile-time constant. =item letters List of characters to be treated as letters (lower-case only). The default is a compile-time constant. =item digits List of characters to be treated as digits (lower-case only). The default is a compile-time constant. =item cache If TRUE, then words will be cached when they are processed. If FALSE, the cache will only be used for stopwords and exceptions. The default is TRUE. =back =cut sub new { # Get the parameters. my ($class, %options) = @_; # Get the options. my $exceptionOption = $options{exceptions} || "$FIG_Config::sproutData/exceptions.txt"; my $stopOption = $options{stops} || "$FIG_Config::sproutData/stopwords.txt"; my $vowels = $options{vowels} || VOWELS; my $letters = $options{letters} || LETTERS; my $digits = $options{digits} || DIGITS; my $cacheFlag = (defined $options{cache} ? $options{cache} : 1); my $cache = {}; # Create the BioWords object. my $retVal = { cache => $cache, cacheFlag => $cacheFlag, stopFile => undef, exceptionFile => undef, stems => {}, VOWEL => $vowels, LETTER => $letters, DIGIT => $digits, WORD => "$letters$digits" }; # Now we need to deal with the craziness surrounding the exception hash and the stop word # list, both of which are loaded into the cache before we start processing anything # serious. The exceptions and stops could be passed in as hash references, in which case # we load them into the cache. Alternatively, they could be file names, which we save # to be read in when we need them. So, first, we check for an exception file name. if (! ref $exceptionOption) { # Here we have a file name. We store it in the object. $retVal->{exceptionFile} = $exceptionOption; } else { # Here we have a hash. Slurp it into the cache. for my $exceptionWord (keys %{$exceptionOption}) { Store($retVal, $exceptionWord, $exceptionOption->{$exceptionWord}, 0); } } # Now we check for a stopword file name. if (! ref $stopOption) { # Store it in the object. $retVal->{stopFile} = $stopOption; } else { # No file name, so slurp in the list of words. for my $stopWord (@{$stopOption}) { Stop($retVal, $stopWord); } } # Bless and return the object. bless $retVal, $class; return $retVal; } =head2 Public Methods =head3 Stop $bio->Stop($word); Denote that a word is a stop word. =over 4 =item word Word to be declared as a stop word. =back =cut sub Stop { # Get the parameters. my ($self, $word) = @_; # Store the stop word. $self->{cache}->{$word} = {stem => EMPTY, phonex => EMPTY, count => 0 }; } =head3 Store $bio->Store($word, $stem, $count); Store a word in the cache. The word will be mapped to the specified stem and its count will be set to the specified value. The phonex will be computed automatically from the stem. This method can also be used to store exceptions. In that case, the count should be C<0>. =over 4 =item word Word to be stored. =item stem Proposed stem. =item count Proposed count. This should be C<0> for exceptions and C<1> for normal words. The default is C<1>. =back =cut sub Store { # Get the parameters. my ($self, $word, $stem, $count) = @_; # Default the count. my $realCount = (defined $count ? $count : 1); # Get the phonex for the specified stem. my $phonex = $self->_phonex($stem); # Store the word in the cache. $self->{cache}->{$word} = { stem => $stem, phonex => $phonex, count => $realCount }; } =head3 Split my @words = $bio->Split($string); Split a string into keywords. A keyword is this context is either a delimiter sequence or a combination of letters, digits, underscores (C<_>), and isolated single quotes (C<'>). All letters are converted to lower case, and any white space sequence inside the string is converted to a single space. Prior to splitting the string, certain strings that have special biological meaning are modified, and certain delimiters are converted. This helps to resolve some ambiguities (e.g. which alias names use colons and which use vertical bars) and makes strings such as EC numbers appear to be singleton keywords. The list of keywords we output can be rejoined and then passed unmodified to a keyword search; however, before doing that the individual pure words should be stemmed and checked for spelling. =over 4 =item string Input string to process. =item RETURN Returns a List of normalized keywords and delimiters. =back =cut sub Split { # Get the parameters. my ($self, $string) = @_; # Convert letters to lower case and collapse the white space. Note that we use the "s" modifier on # the substitution so that new-lines are treated as white space, and we take precautions so that # an undefined input is treated as a null string (which saves us from compiler warnings). my $lowered = (defined($string) ? lc $string : ""); $lowered =~ s/\s+/ /sg; # Trim the leading space (if any). $lowered =~ s/^ //; # Fix the periods in EC and TC numbers. Note here we are insisting on real # digits rather than the things we treat as digits. We are parsing for real EC # and TC numbers, not generalized strings, and the format is specific. $lowered =~ s/(\d+|\-)\.(\d+|-)\.(\d+|-)\.(\d+|-)/$1_$2_$3_$4/g; # Fix non-trailing periods. $lowered =~ s/\.([$self->{WORD}])/_$1/g; # Fix non-leading minus signs. $lowered =~ s/([$self->{WORD}])[\-]/$1_/g; # Fix interior vertical bars and colons $lowered =~ s/([$self->{WORD}])[|:]([$self->{WORD}])/$1'$2/g; # Now split up the list so that each keyword is in its own string. The delimiters between # are kept, so when we're done everything can be joined back together again. Trace("Normalized string is -->$lowered<--") if T(4); my @pieces = map { split(/([^$self->{WORD}]+)/, $_) } $lowered; # The last step is to separate spaces from the other delimiters. my @retVal; for my $piece (@pieces) { while (substr($piece,0,1) eq " ") { $piece = substr($piece, 1); push @retVal, " "; } while ($piece =~ /(.+?) (.*)/) { push @retVal, $1, " "; $piece = $2; } if ($piece ne "") { push @retVal, $piece; } } # Return the result. return @retVal; } =head3 Region1 my $root = $bio->Region1($word); Return the suffix region for a word. This is referred to as I<region 1> in the literature on word stemming, and it consists of everything after the first non-vowel that follows a vowel. =over 4 =item word Lower-case word whose suffix region is desired. =item RETURN Returns the suffix region, or the empty string if there is no suffix region. =back =cut sub Region1 { # Get the parameters. my ($self, $word) = @_; # Declare the return variable. my $retVal = ""; # Look for the R1. if ($word =~ /[$self->{VOWEL}][^$self->{VOWEL}](.+)/i) { $retVal = $1; } # Return the result. return $retVal; } =head3 FindRule my ($prefix, $suffix, $replacement) = BioWords::FindRule($word, @rules); Find the appropriate suffix rule for a word. Suffix rules are specified as pairs in a list. Syntactically, the rule list may look like a hash, but the order of the rules is important, so in fact it is a list. The first rule whose key matches the suffix is applied. The part of the word before the suffix, the suffix itself, and the value of the rule are all passed back to the caller. If no rule matches, the prefix will be the entire input word, and the suffix and replacement will be an empty string. =over 4 =item word Word to parse. It should already be normalized to lower case. =item rules A list of rules. Each rule is represented by two entries in the list-- a suffix to match and a value to return. =item RETURN Returns a three-element list. The first element will be the portion of the word before the matched suffix, the second element will be the suffix itself, and the third will be the replacement recommended by the matched rule. If no rule matches, the first element will be the whole word and the other two will be empty strings. =back =cut sub FindRule { # Get the parameters. my ($word, @rules) = @_; # Declare the return variables. my ($prefix, $suffix, $replacement) = ($word, EMPTY, EMPTY); # Search for a match. We'll stop on the first one. for (my $i = 0; ! $suffix && $i < $#rules; $i += 2) { my $len = length($rules[$i]); if ($rules[$i] eq substr($word, -$len)) { $prefix = substr($word, 0, length($word) - $len); $suffix = $rules[$i]; $replacement = $rules[$i+1]; } } # Return the results. return ($prefix, $suffix, $replacement); } =head3 Process my $stem = $biowords->Process($word); Compute the stem of the specified word and record it in the cache. =over 4 =item word Word to be processed. =item RETURN Returns the stem of the word (which could be the original word itself. If the word is a stop word, returns a null string. =back =cut sub Process { # Get the parameters. my ($self, $word) = @_; # Verify that the cache is initialized. my $cache = $self->_initCache(); # Declare the return variable. my $retVal; # Get the word in lower case and compute its length. my $lowered = lc $word; my $len = length $lowered; # Check to see what type of word it is. if ($lowered =~ /[^$self->{WORD}]/) { # It's delimiters. Return it unchanged and don't record it. $retVal = $lowered; } elsif ($len < $self->{SHORT}) { # It's too short. Treat it as a stop word. $retVal = EMPTY; } elsif (exists $cache->{$retVal}) { # It's already in the cache. Get the cache entry. my $entry = $cache->{$lowered}; $retVal = $entry->{stem}; # If it is NOT a stop word, count it. if ($retVal ne EMPTY) { $entry->{count}++; } } elsif ($len == $self->{SHORT}) { # It's already the minimum length. The stem is the word itself. $retVal = $lowered; # Store it if we're using the cache. if ($self->{cacheFlag}) { $self->Store($lowered, $retVal, 1); } } else { # Here we have a new word. We compute the stem and store it. $retVal = $self->_stem($lowered); # Store the word if we're using the cache. if ($self->{cacheFlag}) { $self->Store($lowered, $retVal, 1); } } # We're done. If the stem is non-empty, add it to the stem list. if ($retVal ne EMPTY) { $self->{stems}->{$retVal} = 1; Trace("\"$word\" stems to \"$retVal\".") if T(3); } else { Trace("\"$word\" discarded by stemmer.") if T(3); } # Return the stem. return $retVal; } =head3 IsWord my $flag = $biowords->IsWord($word); Return TRUE if the specified string is a word and FALSE if it is a delimiter. =over 4 =item word String to examine. =item RETURN Returns TRUE if the string contains no delimiters, else FALSE. =back =cut sub IsWord { # Get the parameters. my ($self, $word) = @_; # Test the word. my $retVal = ($word =~ /^[$self->{WORD}]+$/); # Return the result. return $retVal; } =head3 StemList my @stems = $biowords->StemList(); Return the list of stems found in the last search expression. =cut sub StemList { # Get the parameters. my ($self) = @_; # Return the keys of the stem hash. my @retVal = keys %{$self->{stems}}; return @retVal; } =head3 StemLookup my ($stem, $phonex) = $biowords->StemLookup($word); Return the stem and phonex for the specified word. =over 4 =item word Word whose stem and phonex are desired. =item RETURN Returns a two-element list. If the word is found in the cache, the list will consist of the stem followed by the phonex. If the word is a stop word, the list will consist of two empty strings. =back =cut sub StemLookup { # Get the parameters. my ($self, $word) = @_; # Declare the return variables. my ($stem, $phonex); # Get the cache. my $cache = $self->{cache}; # Check the cache for the word. if (exists $cache->{$word}) { # It's found. Return its data. ($stem, $phonex) = map { $_->{stem}, $_->{phonex} } $cache->{$word}; } else { # It's not found. Compute the stem and phonex. my $lowered = lc $word; $stem = $self->Process($lowered); $phonex = $self->_phonex($stem); } # Return the results. return ($stem, $phonex); } =head3 WordList my $words = $biowords->WordList($keep); Return a list of all of the words that were found by L</AnalyzeSearchExpression>. Stop words will not be included. Because the list could potentially contain millions of words, it is returned as a list reference. =cut sub WordList { # Get the parameters. my ($self) = @_; # Get the cache. my $cache = $self->{cache}; # Declare the return variable. my $retVal; # Extract the desired words from the cache. $retVal = [ grep { $cache->{$_}->{count} } keys %{$cache} ]; # Return the result. return $retVal; } =head3 PrepareSearchExpression my $searchExpression = $bio->PrepareSearchExpression($string); Convert an incoming string to a search expression. The string is split into pieces, the pieces are stemmed and processed into the cache, and then they are rejoined after certain adjustments are made. In particular, words without an operator preceding them are prefixed with a plus (C<+>) so that they are treated as required words. =over 4 =item string Search expression to prepare. =item RETURN Returns a modified version of the search expression with words converted to stems, stop words eliminated, and plus signs placed before unmodified words. =back =cut sub PrepareSearchExpression { # Get the parameters. my ($self, $string) = @_; # Declare the return variable. my $retVal = ""; # Analyze the search expression. my @parts = $self->AnalyzeSearchExpression($string); # Now we have to put the pieces back together. At any point, we need # to know if we are inside quotes or in the scope of an operator. my ($inQuotes, $activeOp) = (0, 0); for my $part (@parts) { # Is this a word? if ($part =~ /[a-z0-9]$/) { # Yes. If no operator is present, add a plus. if (! $activeOp && ! $inQuotes) { $retVal .= "+"; $activeOp = 0; } } else { # Here we have one or more operators. We process them # individually. for my $op (split //, $part) { if ($op eq '"') { # Here we have a quote. if ($inQuotes) { # A close quote turns off operator scope. $inQuotes = 0; $activeOp = 0; } else { # An open quote puts us in quote mode. Words inside # quotes do not need the plus added. $inQuotes = 1; } } elsif ($op eq ' ') { # Spaces detach us from the preceding operator. $activeOp = 0; } else { # Everything else puts us in operator scope. $activeOp = 1; } } } # Add this part to the output string. $retVal .= $part; } # Return the result. return $retVal; } =head3 AnalyzeSearchExpression my @list = $bio->AnalyzeSearchExpression($string); Analyze the components of a search expression and return them to the caller. Statistical information about the words in the expression will have been stored in the cache, and the return value will be a list of stems and delimiters. =over 4 =item string Search expression to analyze. =item RETURN Returns a list of words and delimiters, in an order corresponding to the original expression. Real words will have been converted to stems and stop words will have been converted to empty strings. =back =cut sub AnalyzeSearchExpression { # Get the parameters. my ($self, $string) = @_; # Clear the stem list. $self->{stems} = {}; # Normalize and split the search expression. my @parts = $self->Split($string); # Declare the return variable. my @retVal; # Now we loop through the parts, processing them. for my $part (@parts) { my $stem = $self->Process($part); push @retVal, $stem; Trace("Stem of \"$part\" is \"$stem\".") if T(4); } # Return the result. return @retVal; } =head2 Internal Methods =head3 _initCache my $cache = $biowords->_initCache(); Insure the cache is initialized. If exception and stop word files exist, they will be read into memory and used to populate the cache. A reference to the cache will be returned to the caller. =cut sub _initCache { # Get the parameters. my ($self) = @_; # Check for a stopword file. if ($self->{stopFile}) { # Read the file. my @lines = Tracer::GetFile($self->{stopFile}); # Insert it into the cache. for my $line (@lines) { $self->Stop(lc $line); } # Denote that the stopword file has been processed. $self->{stopFile} = EMPTY; } # Check for an exception list. if ($self->{exceptionFile}) { # Read the file. my @lines = Tracer::GetFile($self->{exceptionFile}); # Loop through the lines. for my $line (@lines) { # Extract the words. my @words = split /\s+/, $line; # Map all of the starting words to the last word. my $stem = pop @words; for my $word (@words) { $self->Store($word, $stem, 0); } } # Denote that the exception file has been procesed. $self->{exceptionFile} = EMPTY; } # Return the cache. return $self->{cache}; } =head3 _stem my $stem = $biowords->_stem($word); Compute the stem of an incoming word. This is an internal method that does not check the cache or do any length checking. =over 4 =item word The word to stem. It must already have been converted to lower case. =item RETURN Returns the stem of the incoming word, which could possibly be the word itself. =back =cut sub _stem { # Get the parameters. my ($self, $word) = @_; # Copy the word so we can mangle it. my $retVal = $word; # Convert consonant "y" to "j". $retVal =~ s/^y/j/; $retVal =~ s/([aeiou])y/$1j/g; # Convert vowel "y" to "i". $retVal =~ tr/y/i/; # Compute the R1 and R2 regions. R1 is everything after the first syllable, # and R2 is everything after the second syllable. my $r1 = $self->Region1($retVal); my $r2 = $self->Region1($r1); # Compute the physical locations of the regions. my $len = length $retVal; my $p1 = $len - length $r1; my $p2 = $len - length $r2; # These variables will be used by FindRule. my ($prefix, $suffix, $ruleValue); # Remove genitives. ($retVal, $suffix, $ruleValue) = FindRule($retVal, q('s') => EMPTY, q('s) => EMPTY, q(') => EMPTY); # Process latin endings. ($prefix, $suffix, $ruleValue) = FindRule($retVal, us => 'i', um => 'a', ae => 'a'); # Latin endings only apply if they follow a consonant. if ($prefix =~ /[^aeiou]$/) { $retVal = "$prefix$ruleValue"; } # Convert plurals to singular. ($prefix, $suffix, $ruleValue) = FindRule($retVal, sses => 'ss', ied => 'i', ies => 'i', s => 's'); if ($ruleValue eq 'i') { # If the prefix length is one, we append an "e". if (length $prefix <= 1) { $ruleValue .= "e" } } elsif ($ruleValue eq 's') { # Here we have a naked "s" at the end. We null it out if the prefix ends in a # consonant or an 'e'. Nulling it will cause the "s" to be removed. if ($prefix =~ /[^aiou]$/) { $ruleValue = EMPTY; } } # Finish the singularization. The possibly-modified rule value is applied to the prefix. # If no rule applied, this has no effect, since the prefix is the whole word and the # rule value is the empty string. $retVal = "$prefix$ruleValue"; # Catch the special "izing" construct. ($prefix, $suffix, $ruleValue) = FindRule($retVal, izing => 'is'); $retVal = "$prefix$ruleValue"; # Convert adverbs to adjectives. ($prefix, $suffix, $ruleValue) = FindRule($retVal, eedli => 'ee', eed => 'ee', ingli => EMPTY, ing => EMPTY, edli => EMPTY, ed => EMPTY); # These rules only apply in limited circumstances. if ($ruleValue eq 'ee') { # The "ee" replacement only applies if it occurs in region 1. If it does not # occur there, then we put the suffix back. if (length($prefix) < $p1) { $ruleValue = $suffix; } } elsif ($suffix) { # Here the rule value is the empty string. It only applies if there is a # vowel in the prefix. if ($prefix !~ /[aeiou]/) { # No vowel, so put the suffix back. $ruleValue = $suffix; } else { # The prefix is now the whole word, because the rule value is the empty # string. Check for ending mutations. We may need to add an "e" or # remove a doubled letter. ($prefix, $suffix, $ruleValue) = FindRule($prefix, at => 'ate', bl => 'ble', iz => 'ize', bb => 'b', dd => 'd', ff => 'f', gg => 'g', mm => 'n', nn => 'n', pp => 'p', rr => 'r', tt => 't'); } } # Apply the modifications. $retVal = "$prefix$ruleValue"; # Now we get serious. Here we're looking for special suffixes. ($prefix, $suffix, $ruleValue) = FindRule($retVal, ational => 'ate', tional => 'tion', enci => 'ence', anci => 'ance', abli => 'able', entli => 'ent', ization => 'ize', izer => 'ize', ation => 'ate', ator => 'ate', alism => 'al', aliti => 'al', alli => 'al', fulness => 'ful', ousness => 'ous', ousli => 'ous', ivness => 'ive', iviti => 'ive', biliti => 'ble', bli => 'ble', logi => 'log', fulli => 'ful', lessli => 'less', cli => 'c', dli => 'd', eli => 'e', gli => 'g', hli => 'h', kli => 'k', mli => 'm', nli => 'n', rli => 'r', tli => 't', alize => 'al', icate => 'ic', iciti => 'ic', ical => 'ic'); # These only apply if they are in R1. if ($ruleValue && length($prefix) >= $p1) { $retVal = "$prefix$ruleValue"; } # Conflate "ence" to "ent" if it's in R2. ($prefix, $suffix, $ruleValue) = FindRule($retVal, ence => 'ent'); if ($ruleValue && length($prefix) >= $p2) { $retVal = "$prefix$ruleValue"; } # Now zap "ful", "ness", "ative", and "ize", but only if they're in R1. ($prefix, $suffix, $ruleValue) = FindRule($retVal, ful => EMPTY, ness => EMPTY, ize => EMPTY); if (length($prefix) >= $p1) { $retVal = $prefix; } # Now we have some suffixes that get deleted if they're in R2. ($prefix, $suffix, $ruleValue) = FindRule($retVal, ement => EMPTY, ment => EMPTY, able => EMPTY, ible => EMPTY, ance => EMPTY, ence => EMPTY, ant => EMPTY, ent => EMPTY, ism => EMPTY, ate => EMPTY, iti => EMPTY, ous => EMPTY, ive => EMPTY, ize => EMPTY, al => EMPTY, er => EMPTY, ic => EMPTY, sion => 's', tion => 't', alli => 'al'); if (length($prefix) >= $p2) { $retVal = $prefix; } # Process the doubled L. ($prefix, $suffix, $ruleValue) = FindRule($retVal, ll => 'l'); $retVal = "$prefix$ruleValue"; # Return the result. return $retVal; } =head3 _phonex my $phonex = $biowords->_phonex($word); Compute the phonetic version of a word. Vowels are ignored, doubled letters are trimmed to singletons, and certain letters or letter combinations are conflated. The resulting word is likely to match a misspelling of the original. This is an internal method. It does not check the cache and it assumes the word has already been converted to lower case. =over 4 =item word Word whose phonetic translation is desired. =item RETURN Returns a more-or-less phonetic translation of the word. =back =cut sub _phonex { # Get the parameters. my ($self, $word) = @_; # Declare the return variable. my $retVal = $word; # Handle some special cases. For typed IDs, we remove the type. For # horrible multi-part chemical names, remove everything in front of # the last underscore. if ($word =~ /_([$self->{LETTER}]+)$/ && length($1) > $self->{SHORT}) { $word = $1; } elsif ($word =~ /^[$self->{LETTER}]+'(.+)$/ && length($1) > $self->{SHORT}) { $word = $1; } # Convert the pesky sibilant combinatorials to their own private symbol. $retVal =~ s/sch|ch|sh/S/g; # Convert PH to F. $retVal =~ s/ph/f/g; # Remove silent constructs. $retVal =~ s/gh//g; $retVal =~ s/^ps/s/; # Convert soft G to J and soft C to S. $retVal =~ s/g(e|i)/j$1/g; $retVal =~ s/c(e|i)/s$1/g; # Convert C to K, S to Z, M to N. $retVal =~ tr/csm/kzn/; # Singlify doubled letters. $retVal =~ tr/a-z//s; # Split off the first letter. my $first = substr($retVal, 0, 1, ""); # Delete the vowels. $retVal =~ s/[$self->{VOWEL}]//g; # Put the first letter back. $retVal = $first . $retVal; # Return the result. return $retVal; } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
