[Bio] / Sprout / BBHCheck.pl Repository:
Log of /Sprout/BBHCheck.pl
Links to mgrast_rel_2008_1110: (view) (download) (as text) (annotate)
Wed Sep 3 20:51:33 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Fixed to only look at NMPDR genomes.
Tue Feb 5 05:47:32 2008 UTC (12 years, 1 month ago) by parrello
Changes since 1.5: +0 -2 lines
Removed obsolete use clauses.
Wed Feb 21 13:16:59 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.4: +6 -28 lines
Updated to use BBH server.
Mon Aug 14 22:53:24 2006 UTC (13 years, 7 months ago) by parrello
Fixed the BBH counting for FIG.
Mon Aug 14 22:15:03 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.2: +10 -6 lines
Fixed the SEED check to use FIG methods instead of a database call.
Mon Aug 14 05:25:50 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.1: +22 -1 lines
Added the ability to check bad genomes against the SEED database.
Mon Aug 14 04:58:30 2006 UTC (13 years, 7 months ago) by parrello
Diff to selected 1.2
Added to permit analysis of missing BBHs.
