[Bio] / Sprout / BBHCheck.pl Repository:
View of /Sprout/BBHCheck.pl
Revision 1.7 - (download) (as text) (annotate)
Wed Sep 3 20:51:33 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_release_2008_09_29, rast_2008_0924, rast_rel_2008_09_30, rast_rel_2008_10_29, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_rel_2009_02_05, mgrast_rel_2008_0625, rast_rel_2008_12_18, mgrast_rel_2008_1110_v2, rast_rel_2008_10_09, mgrast_rel_2008_0919, mgrast_rel_2008_1110, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2009_03_26, rast_rel_2008_11_24
Fixed to only look at NMPDR genomes.
#!/usr/bin/perl -w
=head1 BBH Check
Find all genomes in Sprout without any BBHs. This can be an indicator of bad
data in the SEED.
The currently-supported command-line options are as follows.
=over 4
=item user
Name suffix to be used for log files. If omitted, the PID is used.
=item trace
Numeric trace level. A higher trace level causes more messages to appear. The
default trace level is 2. Tracing will be directly to the standard output
as well as to a C<trace>I<User>C<.log> file in the FIG temporary directory,
where I<User> is the value of the B<user> option above.
=item sql
If specified, turns on tracing of SQL activity.
=item background
Save the standard and error output to files. The files will be created
in the FIG temporary directory and will be named C<err>I<User>C<.log> and
C<out>I<User>C<.log>, respectively, where I<User> is the value of the
=item h
Display this command's parameters and options.
=item phone
Phone number to message when the script is complete.
=back
=cut
use strict;
use Tracer;
use Cwd;
use File::Copy;
use File::Path;
use FIG;
use Sprout;
use SFXlate;
use FIGRules;
# Get the command-line options and parameters.
my ($options, @parameters) = StandardSetup([qw(Sprout) ],
                                              fig => [0, "check the SEED database as well as the Sprout"],
                                              phone => ["", "phone number (international format) to call when load finishes"],
                                           @ARGV);
# Set a variable to contain return type information.
my $rtype;
# Insure we catch errors.
eval {
    # Get a sprout object.
    my $sprout = SFXlate->new_sprout_only();
    # Get the FIG object's DB handle.
    my $fig = SFXlate->new();
    # Get the list of genomes.
    my @genomes = $sprout->Genomes();
    # Get the genome names.
    my %genomeNames = ();
    for my $genome (@genomes) {
        my $name = $sprout->GenusSpecies($genome) . " [$genome]";
        $genomeNames{$name} = $genome;
    # Count the bad genomes.
    my $badGenomes = 0;
    # Process the genomes in name order.
    for my $name (sort keys %genomeNames) {
        my $genome = $genomeNames{$name};
        # Count this genome's BBHs.
        my $count = FIGRules::BatchBBHs("fig|$genome.%", 1e-10);
        # Get the genome name.
        # A count of 0 is bad.
        if (! $count) {
            Trace("$name has no BBHs. ***") if T(1);
            $badGenomes++;
        } else {
            Trace("$name BBH count is $count.") if T(3);
    # Tell the user how bad things are.
    my $total = scalar @genomes;
    Trace("$badGenomes out of $total genomes had no BBHs.") if T(2);
if ($@) {
    Trace("Script failed with error: $@") if T(0);
    $rtype = "error";
} else {
    Trace("Script complete.") if T(2);
    $rtype = "no error";
if ($options->{phone}) {
    my $msgID = Tracer::SendSMS($options->{phone}, "BBH Check terminated with $rtype.");
    if ($msgID) {
        Trace("Phone message sent with ID $msgID.") if T(2);
    } else {
        Trace("Phone message not sent.") if T(2);
1;
