[Bio] / Sprout / AttributeTest.pl Repository:
Log of /Sprout/AttributeTest.pl
Links to mgrast_dev_03312011: (view) (download) (as text) (annotate)
Wed Jan 23 00:54:45 2008 UTC (12 years, 4 months ago) by parrello
Changes since 1.4: +8 -12 lines
Changed so that it can run on a system without a FIG database.
Thu Dec 6 14:58:03 2007 UTC (12 years, 5 months ago) by parrello
Tue Apr 10 04:12:07 2007 UTC (13 years, 1 month ago) by parrello
Changed to high-resolution timers.
Sun Feb 18 21:25:18 2007 UTC (13 years, 3 months ago) by parrello
Changes since 1.1: +266 -17 lines
Added tests for subkey support.
Fri Feb 9 22:58:32 2007 UTC (13 years, 3 months ago) by parrello
Added as a way to test standard attribute capabilities.
