[Bio] / Sprout / AttrKeyConvert.pl Repository:
Log of /Sprout/AttrKeyConvert.pl
Wed Sep 3 20:23:31 2008 UTC (11 years, 4 months ago) by parrello
New script to convert old-format attribute dumps to the new format.
