[Bio] / Sprout / AttrDBRefresh.pl Repository:
Log of /Sprout/AttrDBRefresh.pl
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Mon Jan 19 21:46:21 2009 UTC (11 years, 2 months ago) by parrello
Changes since 1.25: +7 -252 lines
Diff to previous 1.25
ERDB 2.0 support
Wed Sep 3 20:50:24 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.24: +133 -2 lines
Diff to previous 1.24
Added a new function to clean out duplicate entries.
Tue Aug 12 06:06:02 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_08_07
Changes since 1.23: +19 -10 lines
Diff to previous 1.23
Converted to new multi-table design concept for attributes.
Fri Apr 18 02:13:30 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.22: +3 -4 lines
Diff to previous 1.22
Changed default load mode to CONCURRENT.
Tue Feb 5 04:45:51 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.21: +9 -7 lines
Diff to previous 1.21
Changed to make appending the default for an attribute load.
Wed Jan 23 00:55:46 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.20: +34 -65 lines
Diff to previous 1.20
Added support for concurrent loading. Changed so that the FIG object is only created when necessary.
Diff to previous 1.19
Sun Sep 30 20:52:26 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.18: +17 -1 lines
Diff to previous 1.18
Added archiving support and resume function.
Sun Sep 30 03:44:39 2007 UTC (12 years, 6 months ago) by parrello
Diff to previous 1.17
Fixed a trace message.
Wed May 23 02:29:59 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.16: +31 -20 lines
Diff to previous 1.16
Added another attribute maintenance rewriting command.
Wed May 2 06:05:30 2007 UTC (12 years, 11 months ago) by parrello
Bug fix...
Wed May 2 05:53:17 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.14: +23 -0 lines
Added an option to clean predicted values from the database.
Fri Apr 27 22:17:06 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.13: +56 -1 lines
Added a command for fixing bad subkeys.
Mon Mar 12 19:17:43 2007 UTC (13 years ago) by parrello
Changes since 1.12: +19 -0 lines
Added an option to display a key's description.
Mon Mar 12 18:49:03 2007 UTC (13 years ago) by parrello
Changes since 1.11: +14 -2 lines
Added an option to append loaded attributes.
Sun Feb 4 14:05:24 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.10: +10 -2 lines
Added statistics to the space trimmer.
Sun Feb 4 13:05:39 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.9: +316 -12 lines
Changed migrate to allow partial migration of attributes. Added a feature to clean out excess spaces and two HTML reports.
Tue Jan 30 00:27:36 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.8: +0 -9 lines
Removed the obsolete "re_index" option.
Tue Jan 9 01:49:08 2007 UTC (13 years, 2 months ago) by parrello
Added support for the new text search index for attributes.
Fri Dec 15 08:15:24 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.6: +32 -14 lines
Added backup and restore for keys.
Fri Dec 15 03:24:41 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.5: +141 -20 lines
Added migration tool for hundred/hundred attributes. Fixed a bug in the backup utility.
Wed Nov 29 20:28:52 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.4: +66 -34 lines
Converted to another attribute storage strategy.
Tue Nov 28 01:00:08 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.3: +93 -13 lines
Converted to the new attribute system.
Thu Nov 16 19:56:49 2006 UTC (13 years, 4 months ago) by parrello
Added a new FIG_Config parameter that will insure attributes are migrated from the old system to the new system instead of the new system to itself.
Thu Nov 9 21:19:16 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.1: +33 -5 lines
Added code to migrate attributes from the SEED data to the new attribute database.
Fri Nov 3 00:31:36 2006 UTC (13 years, 5 months ago) by parrello
Added to provide a method for refreshing the custom attributes database.
