Parent Directory
Revision Log
ERDB 2.0 support
#!/usr/bin/perl -w # # Copyright (c) 2003-2006 University of Chicago and Fellowship # for Interpretations of Genomes. All Rights Reserved. # # This file is part of the SEED Toolkit. # # The SEED Toolkit is free software. You can redistribute # it and/or modify it under the terms of the SEED Toolkit # Public License. # # You should have received a copy of the SEED Toolkit Public License # along with this program; if not write to the University of Chicago # at info@ci.uchicago.edu or the Fellowship for Interpretation of # Genomes at veronika@thefig.info or download a copy from # http://www.theseed.org/LICENSE.TXT. # package AnnotationSproutLoader; use strict; use Tracer; use ERDB; use base 'BaseSproutLoader'; =head1 Sprout Annotation Load Group Class =head2 Introduction The Load Group includes all of the major annotation data tables. =head3 new my $sl = SproutLoader->new($erdb, $source, $options, @tables); Construct a new SproutLoader object. =over 4 =item erdb [[SproutPm]] object for the database being loaded. =item options Reference to a hash of command-line options. =item tables List of tables in this load group. =back =cut sub new { # Get the parameters. my ($class, $erdb, $options) = @_; # Create the table list. my @tables = sort qw(Annotation IsTargetOfAnnotation SproutUser MadeAnnotation); # Create the BaseSproutLoader object. my $retVal = BaseSproutLoader::new($class, $erdb, $options, @tables); # Return it. return $retVal; } =head2 Public Methods =head3 Generate $sl->Generate(); Generate the data for the annotation data files. =cut sub Generate { # Get the parameters. my ($self) = @_; # Get the sprout object. my $sprout = $self->db(); # Get the FIG object. my $fig = $self->source(); # Check for global mode. if ($self->global()) { # In global mode, we create the built-in users. Trace("Creating default users.") if T(3); $self->PutE(SproutUser => "FIG", description => "Fellowship for Interpretation of Genomes"); $self->PutE(SproutUser => "FIG", description => "Fellowship for Interpretation of Genomes"); } else { # Get the section ID, which is the relevant genome. my $genomeID = $self->section(); # Process the annotations for the specified genome. # Get the current time. my $time = time(); # Create a hash of timestamps. We use this to prevent duplicate time stamps # from showing up for a single PEG's annotations. my %seenTimestamps = (); # Get the genome's annotations. my @annotations = $fig->read_all_annotations($genomeID); Trace("Processing annotations.") if T(2); for my $tuple (@annotations) { # Get the annotation tuple. my ($peg, $timestamp, $user, $text) = @{$tuple}; # Change assignments by the master user to FIG assignments. $text =~ s/Set master function/Set FIG function/s; # Insure the time stamp is valid. if ($timestamp =~ /^\d+$/) { # Here it's a number. We need to insure the one we use to form # the key is unique. my $keyStamp = $timestamp; while ($seenTimestamps{"$peg:$keyStamp"}) { $keyStamp++; } my $annotationID = "$peg:$keyStamp"; $seenTimestamps{$annotationID} = 1; # Insure the user exists. $self->PutE(SproutUser => $user, description => "SEED user"); # Generate the annotation. $self->PutE(Annotation => $annotationID, time => $timestamp, annotation => $text); $self->PutR(IsTargetOfAnnotation => $peg, $annotationID); $self->PutR(MadeAnnotation => $user, $annotationID); } else { # Here we have an invalid time stamp. Trace("Invalid time stamp \"$timestamp\" in annotations for $peg.") if T(1); } } } } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
