[Bio] / Sprout / AnnotationSproutLoader.pm Repository:
View of /Sprout/AnnotationSproutLoader.pm
Revision 1.2 - (download) (as text) (annotate)
Mon Jan 19 21:46:21 2009 UTC (11 years, 2 months ago) by parrello
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, mgrast_dev_04082011, rast_rel_2010_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, rast_rel_2009_05_18, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, rast_rel_2009_07_09, rast_rel_2010_0827, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, rast_rel_2009_03_26, mgrast_dev_10262011, HEAD
Changes since 1.1: +4 -16 lines
ERDB 2.0 support
#!/usr/bin/perl -w
# Public License.
package AnnotationSproutLoader;
    use strict;
    use Tracer;
    use ERDB;
    use base 'BaseSproutLoader';
=head1 Sprout Annotation Load Group Class
=head2 Introduction
The  Load Group includes all of the major annotation data tables.
=head3 new
    my $sl = SproutLoader->new($erdb, $source, $options, @tables);
Construct a new SproutLoader object.
=over 4
=item erdb
[[SproutPm]] object for the database being loaded.
=item options
Reference to a hash of command-line options.
=item tables
List of tables in this load group.
=back
=cut
sub new {
    # Get the parameters.
    my ($class, $erdb, $options) = @_;
    # Create the table list.
    my @tables = sort qw(Annotation IsTargetOfAnnotation SproutUser MadeAnnotation);
    # Create the BaseSproutLoader object.
    my $retVal = BaseSproutLoader::new($class, $erdb, $options, @tables);
    # Return it.
    return $retVal;
=head2 Public Methods
=head3 Generate
    $sl->Generate();
Generate the data for the annotation data files.
=cut
sub Generate {
    my ($self) = @_;
    # Get the sprout object.
    my $sprout = $self->db();
    # Get the FIG object.
    my $fig = $self->source();
    # Check for global mode.
    if ($self->global()) {
        # In global mode, we create the built-in users.
        Trace("Creating default users.") if T(3);
        $self->PutE(SproutUser => "FIG", description => "Fellowship for Interpretation of Genomes");
    } else {
        # Get the section ID, which is the relevant genome.
        my $genomeID = $self->section();
        # Process the annotations for the specified genome.
        # Get the current time.
        my $time = time();
        # Create a hash of timestamps. We use this to prevent duplicate time stamps
        # from showing up for a single PEG's annotations.
        my %seenTimestamps = ();
        # Get the genome's annotations.
        my @annotations = $fig->read_all_annotations($genomeID);
        Trace("Processing annotations.") if T(2);
        for my $tuple (@annotations) {
            # Get the annotation tuple.
            my ($peg, $timestamp, $user, $text) = @{$tuple};
            # Change assignments by the master user to FIG assignments.
            $text =~ s/Set master function/Set FIG function/s;
            # Insure the time stamp is valid.
            if ($timestamp =~ /^\d+$/) {
                # Here it's a number. We need to insure the one we use to form
                # the key is unique.
                my $keyStamp = $timestamp;
                while ($seenTimestamps{"$peg:$keyStamp"}) {
                    $keyStamp++;
                my $annotationID = "$peg:$keyStamp";
                $seenTimestamps{$annotationID} = 1;
                # Insure the user exists.
                $self->PutE(SproutUser => $user, description => "SEED user");
                # Generate the annotation.
                $self->PutE(Annotation => $annotationID, time => $timestamp,
                            annotation => $text);
                $self->PutR(IsTargetOfAnnotation => $peg, $annotationID);
                $self->PutR(MadeAnnotation => $user, $annotationID);
            } else {
                # Here we have an invalid time stamp.
                Trace("Invalid time stamp \"$timestamp\" in annotations for $peg.") if T(1);
1;
