[Bio] / Sprout / AlignmentSaplingLoader.pm Repository:
Log of /Sprout/AlignmentSaplingLoader.pm
Mon Oct 10 13:55:56 2011 UTC (8 years, 5 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Fixed bug in ProjectsOnto load.
Sat Oct 1 10:35:02 2011 UTC (8 years, 6 months ago) by parrello
Conversion to support Postgres for ERDB.
Tue Sep 13 21:07:38 2011 UTC (8 years, 6 months ago) by parrello
CVS Tags: rast_rel_2011_0928
Changes since 1.3: +3 -1 lines
Added Projections to the alignment group.
Fri May 20 19:39:20 2011 UTC (8 years, 10 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1
Changes since 1.2: +11 -2 lines
Added support for loading alignment data after a pre-load dump.
Tue May 3 17:00:31 2011 UTC (8 years, 11 months ago) by parrello
Changes since 1.1: +1 -3 lines
Changed design of the alignment data.
Fri Nov 5 16:51:17 2010 UTC (9 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
More loader updates.
