[Bio] / Sprout / AliasCrunch.pl Repository:
Log of /Sprout/AliasCrunch.pl
Links to mgrast_dev_03312011: (view) (download) (as text) (annotate)
Sun Feb 13 13:02:30 2011 UTC (9 years, 3 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +6 -1 lines
Wed Feb 2 15:47:25 2011 UTC (9 years, 3 months ago) by parrello
Changed the default directory to work for Sapling loads.
Wed Feb 2 15:43:10 2011 UTC (9 years, 3 months ago) by parrello
Changes since 1.7: +57 -52 lines
Fixed to handle missing feature directories.
Tue Dec 14 19:47:40 2010 UTC (9 years, 5 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Fixed to capture more locus tags.
Fri Nov 5 21:07:52 2010 UTC (9 years, 6 months ago) by parrello
CVS Tags: rast_rel_2010_1206
Fri Nov 5 16:51:17 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.4: +6 -1 lines
More loader updates.
Wed Jun 9 20:04:54 2010 UTC (9 years, 11 months ago) by parrello
Changed to handle flaky subsystems without crashing.
Thu Mar 25 16:19:32 2010 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.2: +15 -3 lines
Fixed to find more locus tags.
Wed Aug 19 17:07:54 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.1: +103 -5 lines
Changed to use database for corresponding IDs instead of a flat file that is no longer available.
Thu Apr 2 01:28:49 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09
New script to process aliases.
