[Bio] / Sprout / AliasCrunch.pl Repository:
Log of /Sprout/AliasCrunch.pl
Fri Nov 5 21:07:52 2010 UTC (9 years, 8 months ago) by parrello
CVS Tags: rast_rel_2010_1206
Fri Nov 5 16:51:17 2010 UTC (9 years, 8 months ago) by parrello
Changes since 1.4: +6 -1 lines
More loader updates.
Wed Jun 9 20:04:54 2010 UTC (10 years ago) by parrello
Changed to handle flaky subsystems without crashing.
Thu Mar 25 16:19:32 2010 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.2: +15 -3 lines
Fixed to find more locus tags.
Wed Aug 19 17:07:54 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.1: +103 -5 lines
Changed to use database for corresponding IDs instead of a flat file that is no longer available.
Thu Apr 2 01:28:49 2009 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09
Diff to selected 1.4
New script to process aliases.
