[Bio] / SeedViewer / seedviewer.cgi Repository:
Log of /SeedViewer/seedviewer.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Revision 1.42 - (view) (download) (annotate) - [select for diffs]
Tue Nov 15 19:27:11 2011 UTC (8 years ago) by disz
CVS Tags: mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2
Changes since 1.41: +2 -0 lines
Diff to previous 1.41 , to selected 1.27
Cart management
Revision 1.41 - (view) (download) (annotate) - [select for diffs]
Thu Oct 6 15:12:09 2011 UTC (8 years, 2 months ago) by olson
CVS Tags: mgrast_dev_10262011
Changes since 1.40: +2 -1 lines
Diff to previous 1.40 , to selected 1.27
add link to subsystem editor
Revision 1.40 - (view) (download) (annotate) - [select for diffs]
Thu Sep 29 01:51:35 2011 UTC (8 years, 2 months ago) by olson
CVS Tags: rast_rel_2011_0928
Changes since 1.39: +1 -1 lines
Diff to previous 1.39 , to selected 1.27
fix bad dump call
Revision 1.39 - (view) (download) (annotate) - [select for diffs]
Wed Sep 28 17:24:46 2011 UTC (8 years, 2 months ago) by olson
Changes since 1.38: +1 -1 lines
Diff to previous 1.38 , to selected 1.27
fix typo in logging code
Revision 1.38 - (view) (download) (annotate) - [select for diffs]
Fri Sep 16 19:28:10 2011 UTC (8 years, 2 months ago) by olson
Changes since 1.37: +1 -0 lines
Diff to previous 1.37 , to selected 1.27
add subsytem primer link
Revision 1.37 - (view) (download) (annotate) - [select for diffs]
Thu May 5 21:17:21 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1
Changes since 1.36: +3 -1 lines
Diff to previous 1.36 , to selected 1.27
Add minimal startpage.
Revision 1.36 - (view) (download) (annotate) - [select for diffs]
Wed Jan 26 19:40:29 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.35: +1 -1 lines
Diff to previous 1.35 , to selected 1.27
Minor fixes
Revision 1.35 - (view) (download) (annotate) - [select for diffs]
Fri Jan 21 20:30:33 2011 UTC (8 years, 10 months ago) by olson
Changes since 1.34: +44 -2 lines
Diff to previous 1.34 , to selected 1.27
Add atomic regulon display support.
Revision 1.34 - (view) (download) (annotate) - [select for diffs]
Thu Dec 23 18:03:19 2010 UTC (8 years, 11 months ago) by olson
CVS Tags: rast_rel_2011_0119
Changes since 1.33: +50 -13 lines
Diff to previous 1.33 , to selected 1.27
Caching / FCGI speedup modifications.
Revision 1.33 - (view) (download) (annotate) - [select for diffs]
Mon Oct 12 14:03:02 2009 UTC (10 years, 1 month ago) by paczian
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.32: +21 -109 lines
Diff to previous 1.32 , to selected 1.27
updated help links
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Wed Aug 26 20:33:50 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_0925
Changes since 1.31: +106 -18 lines
Diff to previous 1.31 , to selected 1.27
Performance optimizations; flip to 'die cgi_exit' instead of 'exit'.
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Thu Jul 9 10:03:34 2009 UTC (10 years, 5 months ago) by paczian
CVS Tags: rast_rel_2009_07_09
Changes since 1.30: +0 -1 lines
Diff to previous 1.30 , to selected 1.27
removed requirement for terms of service
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Wed Jul 8 12:45:31 2009 UTC (10 years, 5 months ago) by paczian
Changes since 1.29: +4 -1 lines
Diff to previous 1.29 , to selected 1.27
changed name of default.css to web_app_default.css to resolve name clash
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Wed Jul 8 00:02:57 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.28 , to selected 1.27
Reverse previous incorrect fix.
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Tue Jul 7 23:51:58 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.27
Fixed URL for default.css.
Revision 1.27 - (view) (download) (annotate) - [selected]
Tue Dec 2 16:02:47 2008 UTC (11 years ago) by paczian
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18
Changes since 1.26: +1 -0 lines
Diff to previous 1.26
enabled new scenario package
Thu Oct 16 22:30:43 2008 UTC (11 years, 1 month ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_29, rast_rel_2008_11_24
Changes since 1.25: +2 -1 lines
Diff to previous 1.25 , to selected 1.27
Initial changes to support mod_perl with RAST/SeedViewer:
Template loading requires absolute path. We use TMPL_PATH for this.
add_css used to use TMPL_PATH, but css paths are in URL space, not in
filesystem space. Add new TMPL_URL_PATH to WebConfig and use that instead.
WebApplication::run should not exit; mod_perl doesn't like it and it isn't necessary. Just return.
Thu Oct 2 10:27:39 2008 UTC (11 years, 2 months ago) by paczian
CVS Tags: rast_rel_2008_10_09
Changes since 1.24: +9 -1 lines
Diff to previous 1.24 , to selected 1.27
added contact info check. If $server_type is present in FIG_Config.pm, will change contact mail address accordingly.
Thu Sep 4 18:58:15 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.23: +40 -64 lines
Diff to previous 1.23 , to selected 1.27
Fixed to once again permit seed-mode testing on NMPDR machines. Moved in tracing initialization from WebApplication so that it kicks in immediately instead of at the end of the initialization process.
Wed Sep 3 20:42:27 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.22: +17 -6 lines
Diff to previous 1.22 , to selected 1.27
Fixed to work with the new NMPDR.
Mon Jul 28 14:41:22 2008 UTC (11 years, 4 months ago) by paczian
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.21: +1 -4 lines
Diff to previous 1.21 , to selected 1.27
search box moved from Navigate menu to the right of the menu bar
Mon Jun 2 05:11:53 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.20: +3 -4 lines
Diff to previous 1.20 , to selected 1.27
Removed default.css from NMPDR mode. This fixes several Internet Explorer style problems.
Fri May 9 06:20:03 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.19: +0 -1 lines
Diff to previous 1.19 , to selected 1.27
Tightened up the emergency error code.
Thu May 8 14:42:23 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.18: +3 -1 lines
Diff to previous 1.18 , to selected 1.27
Added some tracing.
Wed May 7 23:04:08 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.17: +5 -6 lines
Diff to previous 1.17 , to selected 1.27
Changed to use "Warn" during error recovery. This will cause Seed Viewer crashes to appear in the RSS error feed.
Thu May 1 07:58:38 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.16: +3 -2 lines
Diff to previous 1.16 , to selected 1.27
Switched to display the NMPDR icon instead of the version when running in Sprout mode.
Tue Apr 29 20:39:07 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.15: +11 -16 lines
Diff to previous 1.15 , to selected 1.27
Fixed menus. Removed sitemeter and tracing support (now handled in framework). Traced errors so we see them in the log.
Sun Mar 23 16:04:27 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.14: +14 -9 lines
Diff to previous 1.14 , to selected 1.27
Shifted around some styles to get the correct override order. Customized some of the menus for NMPDR mode.
Fri Mar 14 17:59:48 2008 UTC (11 years, 8 months ago) by paczian
Diff to previous 1.13 , to selected 1.27
put id box style into stylesheet
Mon Feb 18 21:38:15 2008 UTC (11 years, 9 months ago) by paczian
Changes since 1.12: +1 -0 lines
Diff to previous 1.12 , to selected 1.27
update menu with entry for FigFams
Tue Feb 5 04:44:46 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.11: +0 -1 lines
Diff to previous 1.11 , to selected 1.27
Removed an invalid comment.
Wed Jan 23 21:08:12 2008 UTC (11 years, 10 months ago) by paczian
Diff to previous 1.10 , to selected 1.27
commented out Admin category from the menu. All functionality this used to have should now be included in the AccountManagement page.
Thu Jan 17 21:41:50 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.9: +4 -3 lines
Diff to previous 1.9 , to selected 1.27
added link to 'I forgot my password' to the help menu
Thu Dec 13 17:34:27 2007 UTC (11 years, 11 months ago) by paczian
Changes since 1.8: +6 -5 lines
Diff to previous 1.8 , to selected 1.27
moved sitemeter in here
Thu Dec 13 16:06:17 2007 UTC (11 years, 11 months ago) by paczian
Diff to previous 1.7 , to selected 1.27
added site-meter option, requires FIG_Config::site_meter to be 1
Thu Dec 6 21:17:47 2007 UTC (12 years ago) by paczian
Changes since 1.6: +8 -9 lines
Diff to previous 1.6 , to selected 1.27
added no warnings 'once' to avoid error log spam
Thu Nov 29 16:31:17 2007 UTC (12 years ago) by parrello
Changes since 1.5: +41 -14 lines
Diff to previous 1.5 , to selected 1.27
Updated to work in NMPDR with different styles.
Mon Nov 26 17:29:08 2007 UTC (12 years ago) by paczian
Changes since 1.4: +15 -5 lines
Diff to previous 1.4 , to selected 1.27
moved dbmaster creation to WebApplication.pm
Wed Nov 7 17:09:12 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.3: +7 -6 lines
Diff to previous 1.3 , to selected 1.27
now uses default.css by default (duh!)
Mon Oct 8 19:32:45 2007 UTC (12 years, 2 months ago) by paczian
Changes since 1.2: +3 -12 lines
Diff to previous 1.2 , to selected 1.27
fixed things
Mon Jul 16 16:07:05 2007 UTC (12 years, 4 months ago) by paczian
Changes since 1.1: +21 -13 lines
Diff to previous 1.1 , to selected 1.27
some updates, forgot what
Thu Jun 7 15:05:39 2007 UTC (12 years, 6 months ago) by paczian
Diff to selected 1.27
changed name from index.cgi to avoid naming conflicts
