Log of /SeedViewer/seedviewer.cgi
Parent Directory
Revision
1.18 -
view)
download)
annotate)
[select for diffs]
Wed May 7 23:04:08 2008 UTC (11 years, 7 months ago) by
parrello
Branch:
MAIN
Changes since
1.17: +5 -6 lines
Diff to
previous 1.17
Changed to use "Warn" during error recovery. This will cause Seed Viewer crashes to appear in the RSS error feed.
Revision
1.17 -
view)
download)
annotate)
[select for diffs]
Thu May 1 07:58:38 2008 UTC (11 years, 7 months ago) by
parrello
Branch:
MAIN
Changes since
1.16: +3 -2 lines
Diff to
previous 1.16
Switched to display the NMPDR icon instead of the version when running in Sprout mode.
Revision
1.16 -
view)
download)
annotate)
[select for diffs]
Tue Apr 29 20:39:07 2008 UTC (11 years, 7 months ago) by
parrello
Branch:
MAIN
Changes since
1.15: +11 -16 lines
Diff to
previous 1.15
Fixed menus. Removed sitemeter and tracing support (now handled in framework). Traced errors so we see them in the log.
Revision
1.11 -
view)
download)
annotate)
[select for diffs]
Wed Jan 23 21:08:12 2008 UTC (11 years, 10 months ago) by
paczian
Branch:
MAIN
Changes since
1.10: +1 -1 lines
Diff to
previous 1.10
commented out Admin category from the menu. All functionality this used to have should now be included in the AccountManagement page.
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
