[Bio] / SeedViewer / seedviewer.cgi Repository:
Log of /SeedViewer/seedviewer.cgi
Links to mgrast_dev_03252011: (view) (download) (annotate)
Revision 1.36 - (view) (download) (annotate) - [select for diffs]
Wed Jan 26 19:40:29 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.35: +1 -1 lines
Diff to previous 1.35
Minor fixes
Revision 1.35 - (view) (download) (annotate) - [select for diffs]
Fri Jan 21 20:30:33 2011 UTC (8 years, 10 months ago) by olson
Changes since 1.34: +44 -2 lines
Diff to previous 1.34
Add atomic regulon display support.
Revision 1.34 - (view) (download) (annotate) - [select for diffs]
Thu Dec 23 18:03:19 2010 UTC (8 years, 11 months ago) by olson
CVS Tags: rast_rel_2011_0119
Changes since 1.33: +50 -13 lines
Diff to previous 1.33
Caching / FCGI speedup modifications.
Revision 1.33 - (view) (download) (annotate) - [select for diffs]
Mon Oct 12 14:03:02 2009 UTC (10 years, 1 month ago) by paczian
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.32: +21 -109 lines
Diff to previous 1.32
updated help links
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Wed Aug 26 20:33:50 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_0925
Changes since 1.31: +106 -18 lines
Diff to previous 1.31
Performance optimizations; flip to 'die cgi_exit' instead of 'exit'.
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Thu Jul 9 10:03:34 2009 UTC (10 years, 4 months ago) by paczian
CVS Tags: rast_rel_2009_07_09
Changes since 1.30: +0 -1 lines
Diff to previous 1.30
removed requirement for terms of service
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Wed Jul 8 12:45:31 2009 UTC (10 years, 5 months ago) by paczian
Changes since 1.29: +4 -1 lines
Diff to previous 1.29
changed name of default.css to web_app_default.css to resolve name clash
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Wed Jul 8 00:02:57 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.28
Reverse previous incorrect fix.
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Tue Jul 7 23:51:58 2009 UTC (10 years, 5 months ago) by parrello
Diff to previous 1.27
Fixed URL for default.css.
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Tue Dec 2 16:02:47 2008 UTC (11 years ago) by paczian
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18
Changes since 1.26: +1 -0 lines
Diff to previous 1.26
enabled new scenario package
Thu Oct 16 22:30:43 2008 UTC (11 years, 1 month ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_29, rast_rel_2008_11_24
Changes since 1.25: +2 -1 lines
Diff to previous 1.25
Initial changes to support mod_perl with RAST/SeedViewer:
Template loading requires absolute path. We use TMPL_PATH for this.
add_css used to use TMPL_PATH, but css paths are in URL space, not in
filesystem space. Add new TMPL_URL_PATH to WebConfig and use that instead.
WebApplication::run should not exit; mod_perl doesn't like it and it isn't necessary. Just return.
Thu Oct 2 10:27:39 2008 UTC (11 years, 2 months ago) by paczian
CVS Tags: rast_rel_2008_10_09
Changes since 1.24: +9 -1 lines
Diff to previous 1.24
added contact info check. If $server_type is present in FIG_Config.pm, will change contact mail address accordingly.
Thu Sep 4 18:58:15 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.23: +40 -64 lines
Diff to previous 1.23
Fixed to once again permit seed-mode testing on NMPDR machines. Moved in tracing initialization from WebApplication so that it kicks in immediately instead of at the end of the initialization process.
Wed Sep 3 20:42:27 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.22: +17 -6 lines
Diff to previous 1.22
Fixed to work with the new NMPDR.
Mon Jul 28 14:41:22 2008 UTC (11 years, 4 months ago) by paczian
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.21: +1 -4 lines
Diff to previous 1.21
search box moved from Navigate menu to the right of the menu bar
Mon Jun 2 05:11:53 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.20: +3 -4 lines
Diff to previous 1.20
Removed default.css from NMPDR mode. This fixes several Internet Explorer style problems.
Fri May 9 06:20:03 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.19: +0 -1 lines
Diff to previous 1.19
Tightened up the emergency error code.
Thu May 8 14:42:23 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.18: +3 -1 lines
Diff to previous 1.18
Added some tracing.
Wed May 7 23:04:08 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.17: +5 -6 lines
Diff to previous 1.17
Changed to use "Warn" during error recovery. This will cause Seed Viewer crashes to appear in the RSS error feed.
Thu May 1 07:58:38 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.16: +3 -2 lines
Diff to previous 1.16
Switched to display the NMPDR icon instead of the version when running in Sprout mode.
Tue Apr 29 20:39:07 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.15: +11 -16 lines
Fixed menus. Removed sitemeter and tracing support (now handled in framework). Traced errors so we see them in the log.
Sun Mar 23 16:04:27 2008 UTC (11 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.14: +14 -9 lines
Shifted around some styles to get the correct override order. Customized some of the menus for NMPDR mode.
Fri Mar 14 17:59:48 2008 UTC (11 years, 8 months ago) by paczian
put id box style into stylesheet
Mon Feb 18 21:38:15 2008 UTC (11 years, 9 months ago) by paczian
Changes since 1.12: +1 -0 lines
update menu with entry for FigFams
Tue Feb 5 04:44:46 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.11: +0 -1 lines
Removed an invalid comment.
Wed Jan 23 21:08:12 2008 UTC (11 years, 10 months ago) by paczian
commented out Admin category from the menu. All functionality this used to have should now be included in the AccountManagement page.
Thu Jan 17 21:41:50 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.9: +4 -3 lines
added link to 'I forgot my password' to the help menu
Thu Dec 13 17:34:27 2007 UTC (11 years, 11 months ago) by paczian
Changes since 1.8: +6 -5 lines
moved sitemeter in here
Thu Dec 13 16:06:17 2007 UTC (11 years, 11 months ago) by paczian
added site-meter option, requires FIG_Config::site_meter to be 1
Thu Dec 6 21:17:47 2007 UTC (12 years ago) by paczian
Changes since 1.6: +8 -9 lines
added no warnings 'once' to avoid error log spam
Thu Nov 29 16:31:17 2007 UTC (12 years ago) by parrello
Changes since 1.5: +41 -14 lines
Updated to work in NMPDR with different styles.
Mon Nov 26 17:29:08 2007 UTC (12 years ago) by paczian
Changes since 1.4: +15 -5 lines
moved dbmaster creation to WebApplication.pm
Wed Nov 7 17:09:12 2007 UTC (12 years, 1 month ago) by paczian
Changes since 1.3: +7 -6 lines
now uses default.css by default (duh!)
Mon Oct 8 19:32:45 2007 UTC (12 years, 2 months ago) by paczian
Changes since 1.2: +3 -12 lines
fixed things
Mon Jul 16 16:07:05 2007 UTC (12 years, 4 months ago) by paczian
Changes since 1.1: +21 -13 lines
some updates, forgot what
Thu Jun 7 15:05:39 2007 UTC (12 years, 6 months ago) by paczian
changed name from index.cgi to avoid naming conflicts
