[Bio] / SeedViewer / linkin.cgi Repository:
Log of /SeedViewer/linkin.cgi
Links to mgrast_dev_08112011: (view) (download) (annotate)
Thu Feb 3 22:26:13 2011 UTC (9 years, 5 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, rast_rel_2011_0928
Diff to previous 1.16
exit => die cgi_exit
Fri May 8 08:14:50 2009 UTC (11 years, 2 months ago) by paczian
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.15: +3 -0 lines
all nmpdr| ids will be changed to fig| ids
Mon Mar 23 16:39:40 2009 UTC (11 years, 3 months ago) by paczian
CVS Tags: rast_rel_2009_03_26
Changes since 1.14: +31 -4 lines
added check to the ACH
Fri Sep 19 19:21:30 2008 UTC (11 years, 9 months ago) by wilke
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_release_2008_09_29
Changes since 1.13: +1 -0 lines
Wed Sep 3 20:42:27 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.12: +37 -8 lines
Fixed to work with the new NMPDR.
Mon Jul 7 16:58:53 2008 UTC (12 years ago) by paczian
Changes since 1.11: +8 -1 lines
added link to metagenomes
Mon Jun 23 18:46:20 2008 UTC (12 years ago) by disz
Changes since 1.10: +2 -1 lines
Added subsystem lookup in error page
Fri Jun 20 20:45:45 2008 UTC (12 years ago) by disz
FIxed no susbsystem name error
Fri Jun 20 20:32:20 2008 UTC (12 years ago) by disz
Added subsystem accession number linkin
Tue Jun 17 19:31:26 2008 UTC (12 years, 1 month ago) by disz
Changes since 1.7: +21 -0 lines
Added subsystem linkin by accession number
Thu Jun 5 15:52:41 2008 UTC (12 years, 1 month ago) by paczian
Changes since 1.6: +7 -1 lines
now supports figfams
Fri May 9 06:22:06 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.5: +11 -9 lines
Tightened up the emergency error code.
Tue Apr 29 20:35:37 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.4: +7 -6 lines
Modified to work in a more NMPDR-friendly manner.
Fri Mar 21 15:03:19 2008 UTC (12 years, 3 months ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.3: +12 -6 lines
catching fig ids before checking id correspondence
Tue Mar 11 21:24:18 2008 UTC (12 years, 4 months ago) by paczian
Changes since 1.2: +24 -2 lines
now supports id_correspondence db
Tue Jan 29 15:29:48 2008 UTC (12 years, 5 months ago) by paczian
Changes since 1.1: +7 -5 lines
all new and improved
Wed Dec 19 21:42:35 2007 UTC (12 years, 6 months ago) by paczian
addded the linkin mechanism to SeedViewer v2
