[Bio] / SeedViewer / NmpdrViewer.tmpl Repository:
Log of /SeedViewer/NmpdrViewer.tmpl
Links to mgrast_dev_08112011: (view) (download) (annotate)
Wed May 28 17:40:08 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.5: +11 -12 lines
Updated to more closely match the layout of the wiki.
Tue Apr 29 20:36:35 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.4: +38 -24 lines
Changed header to look like the wiki header.
Fri Mar 14 20:47:19 2008 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.3: +15 -21 lines
Leslie changed the header so that "Quick" is before Search and I removed the bug report button both because it returned an error and because it is now located
 under the help menu.
Tue Feb 5 04:43:36 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.2: +14 -4 lines
Added the menu back.
Thu Nov 29 16:31:17 2007 UTC (12 years, 4 months ago) by parrello
Changes since 1.1: +0 -11 lines
Updated to work in NMPDR with different styles.
Sun Nov 18 17:48:39 2007 UTC (12 years, 4 months ago) by parrello
Added to provide a mechanism for NMPDR look and feel.
