[Bio] / SeedViewer / Makefile Repository:
Log of /SeedViewer/Makefile
Links to mgrast_dev_08112011: (view) (download) (annotate)
Mon Apr 25 20:02:41 2011 UTC (8 years, 11 months ago) by devoid
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1
More files needed for model import pipeline webpage.
Sun Jan 2 21:58:45 2011 UTC (9 years, 2 months ago) by chenry
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2011_0119
Large update rearranging code to utilize PPO database
Mon Dec 22 23:33:47 2008 UTC (11 years, 3 months ago) by olson
CVS Tags: rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.10: +12 -2 lines
Add support for suexec - if CGI directory contains "public_html", ensure that any
installed CGI scripts and the CGI directory itself are not group or world writable.
Tue Sep 9 00:33:19 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Removed the evil cp -p
Wed Jul 16 20:20:25 2008 UTC (11 years, 8 months ago) by jared
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_08_07
Changes since 1.8: +2 -1 lines
added jpg and gif support for image dir
Wed May 7 16:24:59 2008 UTC (11 years, 10 months ago) by paczian
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
removed -p from copy since it causes problems
Mon Mar 24 20:23:36 2008 UTC (12 years ago) by paczian
CVS Tags: rast_rel_2008_04_23
Changes since 1.6: +0 -2 lines
removed rights script
Fri Dec 21 23:05:33 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.5: +3 -3 lines
use the seed perl
Fri Dec 21 22:57:21 2007 UTC (12 years, 3 months ago) by olson
Changes since 1.4: +2 -1 lines
remove rights entirely, since it crashes on new anno-3
Fri Dec 21 19:49:10 2007 UTC (12 years, 3 months ago) by olson
make failure of create_application_rights_module not fatal
Wed Jul 25 16:53:03 2007 UTC (12 years, 8 months ago) by arodri7
modified to add javascript
Mon Jul 16 15:58:52 2007 UTC (12 years, 8 months ago) by paczian
Changes since 1.1: +4 -1 lines
now has rights file creation
Mon Jun 4 20:39:49 2007 UTC (12 years, 9 months ago) by paczian
Branch point for: SeedViewer
