[Bio] / ReleaseTools / sysbiorc.csh Repository:
Log of /ReleaseTools/sysbiorc.csh
Links to V00-00-13: (view) (download) (as text) (annotate)
Wed Sep 1 20:05:31 2004 UTC (15 years, 7 months ago) by efrank
CVS Tags: V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, mass-spec-02, mass-spec-03, preSchematools
these are the group-level env setup files being used at ANL for people
working on kah.  they won't apply to everyone but probably are a reasonable
example of group-level config so i'm putting them in here.
