[Bio] / ReleaseTools / standard.mk Repository:
Log of /ReleaseTools/standard.mk
Links to Branch-bobdev_news: (view) (download) (annotate)
Mon May 16 21:08:04 2005 UTC (14 years, 9 months ago) by efrank
CVS Tags: Root-bobdev_news, caBIG-00-00-00, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, preTreatmanDyn, treatman-lastDay-0
Changes since 1.17: +1 -0 lines
Diff to previous 1.17
mods re makeScriptHeaders which I see now I forgot to do a cvs add on.
feh.
Fri Apr 22 17:58:33 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.16: +20 -2 lines
Diff to previous 1.16
get chagnes back in.  see earlier commit messages for version -3 of this
Fri Apr 22 17:35:12 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.15: +35 -24 lines
revert to 1.14
Fri Apr 22 16:21:44 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.14: +24 -35 lines
start pulling in some of the Seed stuff.
WEBPAGES macro contents now added to bin step and causes copy to cgidir/html
PYTHON_OPEN_CGI macro causes build into cgidir w/ prepend of tool_hdr.  also,
is exccluded from python library list definition.
dot rules to actually do the work.
Wed Apr 13 01:46:06 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.13: +0 -5 lines
remove debugging printout
Wed Apr 13 01:45:12 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.12: +16 -7 lines
do the tried and proven:  for compiled code (.c now), determine a
"library list" from *.c minus any .c specified as a binary file (CBINS)
and minus and .c file explicilty excluded (CEXCLUDES).
all the .c in the library list compile into the libdir (correct behavior
is to compile into the workdir and then ar over into a .a in libdir).  we
then add all the .o to the link line as if there was a library around.
this corresponds to the tried and true: one package is one booch category
is one library.  all that bi-directional 1-1.
missing is formation of the .a and the ability to specify other
releaseTools packages as link dependencies.  i don't think anyone
cares yet.
Tue Apr 12 20:23:17 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.11: +28 -4 lines
add perl to libs and bins
add C for bins.
note- the dot rule to "build" perl stuff does not use tool_hdr in order to keep
kah from breaking, but that's not right for seed.  so for moment, seed
package level makefile overrides the dot rule.  will figure out later.
see als figkernelscripts
Sat Mar 12 03:06:50 2005 UTC (14 years, 11 months ago) by efrank
Changes since 1.10: +3 -3 lines
more battening down hatches against env issues
Fri Mar 11 23:47:53 2005 UTC (14 years, 11 months ago) by efrank
another temp  workaround for fig environment
Fri Mar 11 22:26:14 2005 UTC (14 years, 11 months ago) by efrank
Changes since 1.8: +3 -3 lines
as crutch to get around misconfigured ReleaseTools environment in FIG,
explcitly give path to generatePy, generateDbi, etc.
FIG (fig-user-env) needs to put bin/ of release directory on PATH
Fri Mar 11 16:06:34 2005 UTC (14 years, 11 months ago) by efrank
CVS Tags: gunk
Changes since 1.7: +10 -2 lines
moved __init__ dep from generic .py rule to the generatePy rule in
the schemaTools target.  i don't see the complete chain here yet
but this makes it work for now.
 generate .py from schematools description of class. (Kah related)
    Note- add a __init__ dep because everything is required to be a package
 and so must have an __init__.  putting the dep here is a way to force the
 __init__ to be copied into the dir first so that i can immediately
 be ref'd as a package.  this is needed for schema tools ina way i don't
 grok yet
Fri Mar 11 15:08:54 2005 UTC (14 years, 11 months ago) by efrank
Changes since 1.6: +2 -1 lines
remove bogus dependency on _init__.py for all py tgts
Thu Dec 2 01:54:02 2004 UTC (15 years, 2 months ago) by efrank
CVS Tags: V00-00-15, post-st-migration, post-st-migration2
Changes since 1.5: +14 -3 lines
Add new macro, BINSHSCRIPTS.  Set this to list of borne shell scripts
in package level makefile.
The old BINSCRIPTS is deprecated...although we ignore it now, we will
eventually need to know what kind of script each is so that we can
edit the #! line upon installation, especially for python and perl.
Even for the /usr/bin/env trick!  (was different on gentoo)
We now have BINPYSCRIPTS and BINSHSCRIPTS
Fri Nov 19 18:10:34 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: stMigration0
Changes since 1.4: +17 -6 lines
changes affecting SchemaTools
Tue Oct 5 20:02:31 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
chmod 755 scripts after copied to bin.  feh! upon cvs permissions.
Fri Sep 17 21:04:49 2004 UTC (15 years, 5 months ago) by efrank
Changes since 1.2: +7 -5 lines
mods to support libdir/PackagenameGen directory.
Problem:  If you have package, PkgA, and PkgA has IDL-like stuff in
it that is used to generate code, then python causes problems.  In
our case, we had Foo.st, the input to the schema tools.  Foo.st
was eaten by generatePy to make Foo.py in libdir/PkgA.  Even
though we havfe libdir at the head of PYTHONPATH, python adds
PWD before PYTHONPATH, so if the first import in the execution
snags, say, PkgA.MyClass, then when you later look for PkgA.Foo,
the thing emitted into the libdir, python would not find it because
PkgA was found via PWD.  (This is the caes when trying to run from
the working direction).
So, for each package, we now create  libdir/Pkg and libdir/PkgGen
where the  latter is used to emit generated python.  If a programmer
needs to use a generated .py in an import, they specify
	from PkgGen.TheClass import TheClass
This solves the problem.
Pain in the butt.
Thu Sep 16 21:47:08 2004 UTC (15 years, 5 months ago) by efrank
CVS Tags: preSchematools
Changes since 1.1: +46 -15 lines
Migrate Makefile to standard.mk format.
This commit is everything but Makefile.top (which has the schematools target)
Fri Sep 10 12:54:37 2004 UTC (15 years, 5 months ago) by efrank
So far, we've allowed each package to define all  kinds of rules in its
makefile.  That's wasteful and makesit hard to improve the system because,
when you want new build capabilities, you have to edit all those makefiles,
and users have to know too much.
Gather the business end of the build into standard.mk.  Have package makefiles
include standard.mk.  Modify Makefile.top to have -I so that package makefile
can find standard.mk.  problem solved.  Now package makefiles only need to
define a few macros to describe what to build.
