[Bio] / ReleaseTools / standard.mk Repository:
View of /ReleaseTools/standard.mk
Revision 1.4 - (download) (annotate)
Tue Oct 5 20:02:31 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-4, sc2004-3, sc2004-2, sc2004-1, sc2004-0
chmod 755 scripts after copied to bin.  feh! upon cvs permissions.
# standard.mk
# Centralized make rules, macros, etc., shared amongst the packages.
# Package level makefiles do  not define rules, targets, etc.  Instead,
# they define a few macros needed to generate the build lists and
# standard.mk does the rest.
# The general pattern is to have "all of a kind" selected by wildcard
# into a build product, e.g., all .c or .cc go into a library or
# all .py get .pyc'd into the install area.  But, there are a few
# macro's that define things to exclude, e.g., .c files that have main()
# and are executables or foo.py files that are top-level programs and
# are to be installed in bin as foo.
# A package level makefile does "include standard.mk".  This works because
# of -I's in the Makefile.top in the workdir.  See Makefile.PackageSample.
# Document macros users define in their package level makefiles here:
#BINPYSCRIPTS := script1.py etc.  List of py scripts to install in bin.
#                Installed as script1, not script1.py.  Filtered out of
#                python library list (LIBPYFILES)
#BINSCRIPTS:     List of scripts to be copied to bin verbatim.
#SCHEMATOOLS := file.st, etc.  List of python files defining input to schema
#	        tools.
# Various lists of things to build
#   implemented via macros above.
LIBPYFILES := $(filter-out $(BINPYSCRIPTS), $(wildcard *.py))
# Package-level makefile Targets
# this follows the all: in Makefile.top, but we drop decouple:, makefile:,
# and installdirs:, because those don't make sense at package level
all: schematools lib bin
bin:	$(foreach var, $(BINPYSCRIPTS), $(subst .py,,$(bindir)/$(var))) $(foreach var, $(BINSCRIPTS), $(bindir)/$(var))
lib:	$(foreach var, $(LIBPYFILES), $(libdir)/$(PKGNAME)/$(var))
schematools: $(foreach var, $(subst .st,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var).py) $(foreach var, $(subst .st,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var).sql) $(foreach var, $(subst .st,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var)DbiHandler.py)
test:
clean:
# Rules
# lib related
# verbatim copy from sourcedir to libdir, e.g., py (distutils someday...)
$(libdir)/$(PKGNAME)/%: $(TOPDIR)/$(PKGNAME)/%
	cp -p  $< $@
# generate .py from schematools description of class. (Kah related)
$(libdir)/$(PKGNAME)Gen/%.py: $(TOPDIR)/$(PKGNAME)/%.st
	cd $(libdir)/$(PKGNAME); generatePy $< > $@
# generate .sql from schematools description of class. (Kah related)
$(libdir)/$(PKGNAME)Gen/%.sql: $(TOPDIR)/$(PKGNAME)/%.st
	cd $(libdir)/$(PKGNAME); generateDb $< > $@
# generate object/relational converters from schematools
# description of class. (Kah related)
$(libdir)/$(PKGNAME)Gen/%DbiHandler.py: $(TOPDIR)/$(PKGNAME)/%.st
	cd $(libdir)/$(PKGNAME); generateDbiHandler $< > $@
# bin related
# python scripts. make script, "foo" from "foo.py".  (rewrite path #! someday)
$(bindir)/%: $(TOPDIR)/$(PKGNAME)/%.py
	cp -p  $< $@
	chmod 755 $@
# scripts to copy verbatim.
	cp -p  $< $@
	chmod 755 $@
# Dependency generation
# not written yet.  (of all the things not to have...)
