[Bio] / ReleaseTools / standard.mk Repository:
View of /ReleaseTools/standard.mk
Revision 1.15 - (download) (annotate)
Fri Apr 22 16:21:44 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.14: +24 -35 lines
start pulling in some of the Seed stuff.
WEBPAGES macro contents now added to bin step and causes copy to cgidir/html
PYTHON_OPEN_CGI macro causes build into cgidir w/ prepend of tool_hdr.  also,
is exccluded from python library list definition.
dot rules to actually do the work.
# standard.mk
# Centralized make rules, macros, etc., shared amongst the packages.
# Package level makefiles do  not define rules, targets, etc.  Instead,
# they define a few macros needed to generate the build lists and
# standard.mk does the rest.
# The general pattern is to have "all of a kind" selected by wildcard
# into a build product, e.g., all .c or .cc go into a library or
# all .py get .pyc'd into the install area.  But, there are a few
# macro's that define things to exclude, e.g., .c files that have main()
# and are executables or foo.py files that are top-level programs and
# are to be installed in bin as foo.
# A package level makefile does "include standard.mk".  This works because
# of -I's in the Makefile.top in the workdir.  See Makefile.PackageSample.
# Document macros users define in their package level makefiles here:
# WEBPAGES     : list of stuff to copy to $(cgidir)/Html.  built in bin: step
# PYTHON_OPEN_CGI : list of py scripts to install as cgi scripts in bin step
# BINPYSCRIPTS := script1.py etc.  List of py scripts to install in bin.
#                Installed as script1, not script1.py.  Filtered out of
#                python library list (LIBPYFILES)
# BINSHSCRIPTS:   List of borne shell scripts to be copied to bin verbatim.
# SCHEMATOOLS := file.py, etc.  List of python files defining input to schema
#	        tools.
# BINSCRIPTS:     List of scripts to be copied to bin verbatim.
#                *** migrate away from BINSCRIPTS!  The extra info that
#                *** its borne shell, py, etc., will let us edit the #! line
#                *** during installation, eventually.
# Various lists of things to build
#   implemented via macros above.
LIBPYFILES := $(filter-out $(BINPYSCRIPTS) $(PYTHON_OPEN_CGI) $(SCHEMATOOLS), $(wildcard *.py))
# Package-level makefile Targets
# this follows the all: in Makefile.top, but we drop decouple:, makefile:,
# and installdirs:, because those don't make sense at package level
all: schematools lib bin
bin:	$(foreach var, $(BINPYSCRIPTS), $(subst .py,,$(bindir)/$(var))) $(foreach var, $(BINSHSCRIPTS), $(subst .sh,,$(bindir)/$(var))) $(foreach var, $(BINSCRIPTS), $(bindir)/$(var))  opencgi webpages
lib:	$(foreach var, $(LIBPYFILES), $(libdir)/$(PKGNAME)/$(var))
opencgi: $(foreach var, $(PYTHON_OPEN_CGI), $(subst .py,.cgi, $(cgidir)/$(var)))
webpages: $(foreach var, $(WEBPAGES), $(cgidir)/Html/$(var))
schematools: stDeclFiles stGeneratedFiles
stDeclFiles: $(foreach var, $(SCHEMATOOLS), $(libdir)/$(PKGNAME)/$(var))
stGeneratedFiles: $(foreach var, $(subst .py,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var)_st.py) $(foreach var, $(subst .py,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var).sql) $(foreach var, $(subst .py,,$(SCHEMATOOLS)), $(libdir)/$(PKGNAME)Gen/$(var)DbiHandler.py)
test:
clean:
# Rules
# lib related
$(libdir)/$(PKGNAME)/%.py: $(TOPDIR)/$(PKGNAME)/%.py
	cp -p  $< $@
$(libdir)/$(PKGNAME)/__init__.py: $(TOPDIR)/$(PKGNAME)/__init__.py
	cp -p  $< $@
# verbatim copy from sourcedir to libdir, e.g., py (distutils someday...)
# keep this overly generic one below the more specific py, above.
$(libdir)/$(PKGNAME)/%: $(TOPDIR)/$(PKGNAME)/%
	cp -p  $< $@
# generate .py from schematools description of class. (Kah related)
#    Note- add a __init__ dep because everything is required to be a package
# and so must have an __init__.  putting the dep here is a way to force the
# __init__ to be copied into the dir first so that i can immediately
# be ref'd as a package.  this is needed for schema tools ina way i don't
# grok yet
$(libdir)/$(PKGNAME)Gen/%_st.py: $(TOPDIR)/$(PKGNAME)/%.py  $(libdir)/$(PKGNAME)/__init__.py
	cd $(libdir)/$(PKGNAME); env PYTHONPATH=$(libdir) $(bindir)/generatePy $< > $@
# generate .sql from schematools description of class. (Kah related)
$(libdir)/$(PKGNAME)Gen/%.sql: $(TOPDIR)/$(PKGNAME)/%.py
	cd $(libdir)/$(PKGNAME); env PYTHONPATH=$(libdir) $(bindir)/generateDb $< > $@
# generate object/relational converters from schematools
# description of class. (Kah related)
$(libdir)/$(PKGNAME)Gen/%DbiHandler.py: $(TOPDIR)/$(PKGNAME)/%.py
	$(libdir)/$(PKGNAME); env PYTHONPATH=$(libdir) $(bindir)/generateDbiHandler $< > $@
# bin related
# python scripts. make script, "foo" from "foo.py".  (rewrite path #! someday)
$(bindir)/%: $(TOPDIR)/$(PKGNAME)/%.py
	cp -p  $< $@
	chmod 755 $@
# borne shell scripts
$(bindir)/%: $(TOPDIR)/$(PKGNAME)/%.sh
	cp -p  $< $@
	chmod 755 $@
# scripts to copy verbatim.
	cp -p  $< $@
	chmod 755 $@
# cgi related
$(cgidir)/Html/%: $(TOPDIR)/$(PKGNAME)/%
	cp -p $< $(cgidir)/Html/.
$(cgidir)/%.cgi: $(TOPDIR)/$(PKGNAME)/%.py $(TOOL_HDR_PY)
	( cat $(TOOL_HDR_PY) $< > $@; chmod +x $@ )
# Dependency generation
# not written yet.  (of all the things not to have...)
