[Bio] / ReleaseTools / newrel Repository:
Log of /ReleaseTools/newrel
Links to mass-spec-02: (view) (download) (annotate)
Fri Mar 26 19:46:26 2004 UTC (15 years, 7 months ago) by efrank
CVS Tags: HEAD, Root-bobdev_news, V00-00-08, V00-00-09, V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, V00-00-15, before-dynamics-persistence, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, forRick-14Jul04-0, forRick-14Jul04-1, gunk, lwc, makeScriptHeaders, mass-spec-01, mass-spec-02, mass-spec-03, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, post-st-migration, post-st-migration2, preSchematools, preTreatmanDyn, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0, treatman-lastDay-0
xeq bit
Tue Dec 23 13:43:25 2003 UTC (15 years, 10 months ago) by efrank
CVS Tags: V00-00-07
Changes since 1.2: +29 -8 lines
Modify newrel so that it copies top level makefile from ReleaseTools
into the new release and then does make installdirs.
The ReleaseTools to use is the one in the PackageVersions file given
to newrel.  If ReleaseTools isn't in that file, a warning is printed
but we do as much as we can.
Mon Dec 22 20:56:36 2003 UTC (15 years, 10 months ago) by efrank
CVS Tags: V00-00-06
Changes since 1.1: +163 -9 lines
newrel:
  now makes a new release.  see header for description.  basically,
   you tell it the name of the release to make, it makes sure it isn't
   laready in the release area then takes a file you give it and
   it it uses it as a PackageVersions file.  then it checks everything
   out and rm's the CVS subdirs.
Mon Dec 1 15:16:53 2003 UTC (15 years, 11 months ago) by efrank
Branch point for: orig
