[Bio] / ReleaseTools / newrel Repository:
Log of /ReleaseTools/newrel
Links to V00-00-06: (view) (download) (annotate)
Mon Dec 22 20:56:36 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-06
Changes since 1.1: +163 -9 lines
newrel:
  now makes a new release.  see header for description.  basically,
   you tell it the name of the release to make, it makes sure it isn't
   laready in the release area then takes a file you give it and
   it it uses it as a PackageVersions file.  then it checks everything
   out and rm's the CVS subdirs.
Mon Dec 1 15:16:53 2003 UTC (16 years, 2 months ago) by efrank
Branch point for: orig
