[Bio] / ReleaseTools / makeScriptHeaders Repository:
View of /ReleaseTools/makeScriptHeaders
Revision 1.6 - (download) (annotate)
Thu Apr 17 21:00:10 2008 UTC (11 years, 10 months ago) by olson
CVS Tags: rast_rel_2008_06_18, rast_rel_2008_12_18, rast_rel_2008_07_21, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_09_30, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, mgrast_rel_2008_0625, rast_rel_2008_10_09, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, mgrast_rel_2008_1110, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_08_07
RAST installation tweaks.
#!/usr/bin/env python
# Uses configuration information to generate headers to be prepended onto
# scripts.  For example, for Perl and Python scripts, we prepend the
# location of the interpetter via the #! line and set paths.
# The actions of this script are determined by information in external
# configuration files which are read and then used to emit the header.
# We look for these in
#    1. Base release                        $RTDIST/$RTCURRENT/ReleaseTools/
#    2. Site configuration directory        $RTSITECONFIGDIR/
#    3. Present sandbox/workdir             $PWD/ReleaseTools/
# Each level takes precedence over the preceding one, e.g., #2 trumps #1.
# In each of those directories, we look for a file called RTConfig in
# which one or more of the following lines may be present:
# (see also configParams array below)
# RTENV=path to env.  If absent, /usr/bin/env is used
# RTPYTHON='path of python interpreter'
# RTPERL='path of perl interpreter'
# These are put between thisRel:baseRel and existing pythonpath:
# RTPYTHONPATH='colon separated python path'
# RTPERL5LIB='colon separated perl path'
# These are aditional imports  or use statements
# RTPYTHONIMPORTS='colon separated list of python stuff to force import of'
# RTPERLIMPORTS='colon separated list of perl stuff to force import of'
# BUGS:
#   o
# History:
#   29 apr 05 efrank  First version
import os
import sys
# These are the only allowed keywords in the config file:
configParms =  ["RTENV", "RTPYTHON", "RTPERL", "RTPYTHONPATH", "RTPERL5LIB",
                "RTPYTHONIMPORTS", "RTPERLIMPORTS", "RTSETENV" ]
configParmsMultipleValues = ["RTSETENV"]
def warn(msg, die=0):
   if die:
      print "Fatal Error: %s" % msg
      sys.exit(1)
   else:
      print "Warning: %s" % msg
   return
def getInfo(path, fname):
   @type path: string
   @rtype:  dictionary mapping var names to values
   global configParms
   d={}
   if path==None: return d
   fullpath = os.path.join(path, fname)
   try:
      f=file( fullpath, "r" )
   except Exception, e:
      warn("No config file %s" % fullpath )
      return d
   line = f.readline()
   while (line):
      line = line[:-1].strip()
      if (( not line=="") and (not line[0]=="#" )):
         toks = line.split('=', 1)
         if (not len(toks) == 2):
            warn("Format error in %s: %s" % (fullpath, line), die=1)
         (name, val) = toks
         if (not name in configParms):
            warn("Unknown config param in %s: %s" % (fullpath, name))
         elif name in configParmsMultipleValues:
            if not d.has_key(name):
               d[name] = []
            d[name].append(val)
         else:
            d[name] = val
      line = f.readline()
   return d
def supercede(baseInfo, siteInfo, thisRelInfo):
   Apply precedence rules
   global configParms
   result={}
   # make sure there's something for each.  simplifies code
   # downstream.
   for k in configParms:
      result[k] = ""
   #precendence order is current beats site beats base
   for d in [baseInfo, siteInfo, thisRelInfo]:
         if d.has_key(k): result[k] = d[k]
   return result
def audit( finalParms ):
   @type finalParms: dict
   @rtype: bool/int  true for all ok
   result = 1
   if (finalParms["RTENV"] == ""):
      finalParms["RTENV"] = "/usr/bin/env"
   if (finalParms["RTPYTHON"] == ""):
      warn("RTPYTHON not set in config file")
      result = 0
   if (finalParms["RTPERL"] == ""):
      warn("RTPERL not set in config file")
      result = 0
   return result
def makePerl5LibPath(params):
   Need perl5lib in a couple places, so encapsulate its definition.
   s = "%(THISRELLIB)s:%(THISRELLIB)s/FigKernelPackages:%(THISRELLIB)s/WebApplication:%(THISRELLIB)s/FortyEight:%(THISRELLIB)s/PPO:%(THISRELLIB)s/RAST:%(THISRELLIB)s/SeedViewer:%(BASERELLIB)s:%(BASERELLIB)s/FigKernelPackages:%(RTPERL5LIB)s" % params
   return s
def emitPython( params, filename ):
   hdr =  """#!%(RTENV)s %(RTPYTHON)s
import sys, os
#Precedence order for python: workdir beats baserel beats extra stuff"
""" % params
   #take care: insert pushes to first on list, but colon separated
   # list is in order of precedence...gets confusing but have to
   # reverse the order, that's why not s += foo but s = foo + s belowb.
   s=""
   for p in params["RTPYTHONPATH"].split(":"):
      if p=="": continue
      s = "sys.path.insert(0,'%s')\n" % p + s
   hdr += s
   hdr += """
sys.path.insert(0,"%(BASERELLIB)s")
sys.path.insert(0,"%(THISRELLIB)s" )
""" % params
   hdr += """
if os.getenv("PERL5LIB", "") != "":
   _delim = ":"
else:
   _delim = ""
os.environ["PERL5LIB"]="%s"  +  _delim + os.getenv("PERL5LIB", "")
""" % makePerl5LibPath( params)
   for x in params["RTPYTHONIMPORTS"].split(":"):
      hdr += "import %s\n" % x
   # Write additional environment variables.
   if params.has_key("RTSETENV"):
      for env in params['RTSETENV']:
         k, v = env.split("=",  1)
         hdr += """os.environ["%s"] = "%s"\n""" % (k, v)
   hdr += "# end of tool_hdr_py \n"
   hdr += "#"*72
   hdr += "\n"
   try:
      f=file(filename, 'w')
      f.write( hdr )
      f.close()
   except:
      warn( "Could not write python tool header %s" % (filename), die=1)
   return
def emitPerl( params, filename ):
   # If we are using run_perl as the perl interpreter, we prepand
   # the perl path items instead of hard-setting hte path.
   myparams = params.copy()
   if params['RTPERL'].endswith('/run_perl'):
	myparams['init'] = 'unshift @INC, qw('
   else:
   	myparams['init'] = '@INC = qw('
   hdr =  """#!%(RTENV)s %(RTPERL)s
BEGIN {
    %(init)s
""" % myparams
   for p in makePerl5LibPath( params).split(":"):
      hdr += "              %s\n" % p
   hdr += """
use Data::Dumper;
use Carp;
   for x in params["RTPERLIMPORTS"].split(":"):
      hdr += "use %s;\n" % x
         hdr += """$ENV{'%s'} = "%s";\n""" % (k, v)
   hdr += "# end of tool_hdr\n"
   hdr += "#"*72
   hdr += "\n"
   try:
      f.write( hdr )
      f.close()
   except:
      warn( "Could not write perl tool header", die=1)
   return
def main():
   if (not len(sys.argv) == 2):
      print "usage: makeScriptHeaders releaseDirPath"
      sys.exit(1)
   thisrel         = sys.argv[1]
   rtdist          = os.getenv("RTDIST")
   rtarch          = os.getenv("RTARCH")
   rtcurrent       = os.getenv("RTCURRENT")
   rtsiteconfigdir = os.getenv("RTSITECONFIGDIR")
   if (None==rtdist): warn("RTDIST not set", die=1)
   if (None==rtarch): warn("RTARC not set", die=1)
   if (None==rtcurrent): warn("RTCURRENT not set", die=1)
   #it is not an error for RtSiteconfigDir to be unset
   # However, during the transition from pre-RTConfig to post-RTConfig in the SEED,
   # we check for the existence of an RTConfig in RTROOT/config. If it's there,
   # RTROOT/config is set as the site config dir.
   if rtsiteconfigdir is None:
      rtroot = os.getenv("RTROOT")
      if rtroot is not None:
         otherPath = os.path.join(rtroot, "config", "RTConfig")
         if os.path.isfile(otherPath):
            rtsiteconfigdir = os.path.join(rtroot, "config")
   baserel = os.path.join(rtdist, rtcurrent)
   baseInfo    = getInfo( os.path.join(rtdist, rtcurrent, "ReleaseTools"), "RTConfig")
   siteInfo    = getInfo( rtsiteconfigdir,  "RTConfig")
   thisRelInfo = getInfo( thisrel, "RTConfig" )
   #let different sources of info duke it out:
   finalParms = supercede(baseInfo, siteInfo, thisRelInfo)
   perl_hdr = os.path.join(thisrel, rtarch, "tool_hdr")
   python_hdr = os.path.join(thisrel, rtarch, "tool_hdr_py")
   #make sure no goofiness
   if not  audit( finalParms ):
      # If the header files we are generating are already there,
      # warn and exit with exit status 0 so a make will continue.
      if os.path.isfile(perl_hdr) and os.path.isfile(python_hdr):
         warn("Value errors in config data, but output files already exist. Not failing.", die=0)
         sys.exit(0)
      else:
         warn("Value errors in config data", die=1)
   #slip in a few extras that make coding emitters easier
   finalParms["BASERELLIB"] = "%s" % os.path.join(baserel, rtarch, "lib")  #not really right !!!
   finalParms["THISRELLIB"] = "%s" % os.path.join(thisrel, rtarch, "lib")
   emitPython(finalParms, python_hdr)
   emitPerl(finalParms, perl_hdr)
   return
if (__name__ == "__main__"):
   main()
