[Bio] / ReleaseTools / RTPath.sh Repository:
Log of /ReleaseTools/RTPath.sh
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Fri May 6 21:44:38 2005 UTC (15 years, 1 month ago) by efrank
CVS Tags: HEAD, Root-bobdev_news, before-dynamics-persistence, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, lwc, makeScriptHeaders, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, preTreatmanDyn, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29, treatman-lastDay-0
move workdir release paths up to top in precedence.
Fri Jan 7 16:10:34 2005 UTC (15 years, 4 months ago) by efrank
CVS Tags: gunk
Changes since 1.4: +8 -6 lines
turn off using rtConfig
Fri Sep 3 17:29:27 2004 UTC (15 years, 9 months ago) by efrank
CVS Tags: V00-00-14, V00-00-15, post-st-migration, post-st-migration2, preSchematools, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0
make such that it looks at rtConfig if it exists, at RTCURRENT otherwise
Fri Sep 3 17:20:49 2004 UTC (15 years, 9 months ago) by efrank
CVS Tags: V00-00-12, V00-00-13
Changes since 1.2: +3 -1 lines
use rtConfig from the work directory to set paths correctly
Thu Sep 2 01:45:02 2004 UTC (15 years, 9 months ago) by efrank
CVS Tags: V00-00-11, mass-spec-03
Changes since 1.1: +11 -15 lines
equiv to RTPath.csh
Wed Sep 1 21:02:31 2004 UTC (15 years, 9 months ago) by efrank
add bourne shell version of rtpath
