[Bio] / ReleaseTools / RTPath.sh Repository:
Log of /ReleaseTools/RTPath.sh
Links to preSchematools: (view) (download) (as text) (annotate)
Fri Sep 3 17:29:27 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-14, V00-00-15, post-st-migration, post-st-migration2, preSchematools, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0
make such that it looks at rtConfig if it exists, at RTCURRENT otherwise
Fri Sep 3 17:20:49 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-12, V00-00-13
Changes since 1.2: +3 -1 lines
use rtConfig from the work directory to set paths correctly
Thu Sep 2 01:45:02 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-11, mass-spec-03
Changes since 1.1: +11 -15 lines
equiv to RTPath.csh
Wed Sep 1 21:02:31 2004 UTC (15 years, 8 months ago) by efrank
Diff to selected 1.3
add bourne shell version of rtpath
