[Bio] / ReleaseTools / RTPath.csh Repository:
Log of /ReleaseTools/RTPath.csh
Links to mobedac_release_05302012: (view) (download) (as text) (annotate)
Fri May 6 21:44:38 2005 UTC (14 years, 7 months ago) by efrank
CVS Tags: HEAD, Root-bobdev_news, before-dynamics-persistence, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, lwc, makeScriptHeaders, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, preTreatmanDyn, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29, treatman-lastDay-0
move workdir release paths up to top in precedence.
Fri Jan 7 16:10:34 2005 UTC (14 years, 11 months ago) by efrank
CVS Tags: gunk
Changes since 1.3: +6 -6 lines
turn off using rtConfig
Fri Oct 15 18:03:48 2004 UTC (15 years, 1 month ago) by efrank
CVS Tags: V00-00-15, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0
Changes since 1.2: +8 -1 lines
remove space in pythonpath
Fri Mar 26 20:33:14 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-09, V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03, preSchematools
fix foo=bar vs. setenv foo bar
Fri Feb 6 21:16:57 2004 UTC (15 years, 10 months ago) by efrank
CVS Tags: V00-00-06, V00-00-07, V00-00-08
RTPath.csh
   o source it when in a work directory
   o sets various paths, e.g., path and PYTHONPATH
   o this implements the run-time override hierarchy: work dir, site override, base
     release.
