[Bio] / ReleaseTools / RTPath.csh Repository:
Log of /ReleaseTools/RTPath.csh
Links to mass-spec-01: (view) (download) (as text) (annotate)
Fri Mar 26 20:33:14 2004 UTC (15 years, 10 months ago) by efrank
CVS Tags: V00-00-09, V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03, preSchematools
fix foo=bar vs. setenv foo bar
Fri Feb 6 21:16:57 2004 UTC (16 years ago) by efrank
CVS Tags: V00-00-06, V00-00-07, V00-00-08
RTPath.csh
   o source it when in a work directory
   o sets various paths, e.g., path and PYTHONPATH
   o this implements the run-time override hierarchy: work dir, site override, base
     release.
