[Bio] / ReleaseTools / RTPath.csh Repository:
Log of /ReleaseTools/RTPath.csh
Links to post-st-migration2: (view) (download) (as text) (annotate)
Fri Oct 15 18:03:48 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: V00-00-15, post-st-migration, post-st-migration2, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0
Changes since 1.2: +8 -1 lines
remove space in pythonpath
Fri Mar 26 20:33:14 2004 UTC (15 years, 9 months ago) by efrank
CVS Tags: V00-00-09, V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03, preSchematools
fix foo=bar vs. setenv foo bar
Fri Feb 6 21:16:57 2004 UTC (15 years, 11 months ago) by efrank
CVS Tags: V00-00-06, V00-00-07, V00-00-08
RTPath.csh
   o source it when in a work directory
   o sets various paths, e.g., path and PYTHONPATH
   o this implements the run-time override hierarchy: work dir, site override, base
     release.
