[Bio] / ReleaseTools / Makefile Repository:
Log of /ReleaseTools/Makefile
Links to rast_rel_2008_07_21: (view) (download) (annotate)
Mon May 16 21:08:04 2005 UTC (14 years, 6 months ago) by efrank
CVS Tags: HEAD, Root-bobdev_news, before-dynamics-persistence, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, lwc, makeScriptHeaders, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, preTreatmanDyn, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29, treatman-lastDay-0
Changes since 1.9: +2 -1 lines
mods re makeScriptHeaders which I see now I forgot to do a cvs add on.
feh.
Wed Feb 23 20:59:16 2005 UTC (14 years, 9 months ago) by efrank
CVS Tags: gunk
may be a Real Bad Idea [TM] but tries to be a command that encapsulates what a
person does to promote a package into the lightweight release.  You can run
it in a package or in a sandbox.  It will do either just the one package or
all of the ones in the sandbox.
Thu Sep 16 21:47:08 2004 UTC (15 years, 2 months ago) by efrank
CVS Tags: V00-00-15, post-st-migration, post-st-migration2, preSchematools, sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4, stMigration0
Changes since 1.7: +10 -13 lines
Migrate Makefile to standard.mk format.
This commit is everything but Makefile.top (which has the schematools target)
Tue May 4 16:25:56 2004 UTC (15 years, 7 months ago) by olson
CVS Tags: V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.6: +8 -1 lines
Update ../Makefile if we have a new Makefile.top
Fri Mar 26 19:52:20 2004 UTC (15 years, 8 months ago) by efrank
CVS Tags: V00-00-08, V00-00-09
add scripts to makefile
Wed Dec 3 02:31:02 2003 UTC (16 years ago) by efrank
CVS Tags: V00-00-04, V00-00-05, V00-00-06, V00-00-07, delong-01, delong-02
Changes since 1.4: +5 -0 lines
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:39:16 2003 UTC (16 years ago) by efrank
Mon Dec 1 20:59:29 2003 UTC (16 years ago) by efrank
CVS Tags: V00-00-02, V00-00-03
add PKGNAME to Makefile.top
add CGI subdir to workdirectory in mkworkdir
Mon Dec 1 15:25:34 2003 UTC (16 years ago) by efrank
CVS Tags: V00-00-01
Changes since 1.1: +6 -0 lines
mods to make consistent with makefile name shaffle.
Mon Dec 1 15:18:33 2003 UTC (16 years ago) by efrank
CVS Tags: V00-00-00
first verion of top level makefile.  this thing goes into the work directory
and drives the make.
just a comment file right now
