[Bio] / ReleaseTools / Makefile Repository:
Log of /ReleaseTools/Makefile
Links to V00-00-10: (view) (download) (annotate)
Tue May 4 16:25:56 2004 UTC (15 years, 10 months ago) by olson
CVS Tags: V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.6: +8 -1 lines
Update ../Makefile if we have a new Makefile.top
Revision 1.6 - (view) (download) (annotate) - [selected]
Fri Mar 26 19:52:20 2004 UTC (16 years ago) by efrank
CVS Tags: V00-00-08, V00-00-09
add scripts to makefile
Wed Dec 3 02:31:02 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-04, V00-00-05, V00-00-06, V00-00-07, delong-01, delong-02
Changes since 1.4: +5 -0 lines
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:39:16 2003 UTC (16 years, 4 months ago) by efrank
Mon Dec 1 20:59:29 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-02, V00-00-03
add PKGNAME to Makefile.top
add CGI subdir to workdirectory in mkworkdir
Mon Dec 1 15:25:34 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-01
Changes since 1.1: +6 -0 lines
mods to make consistent with makefile name shaffle.
Mon Dec 1 15:18:33 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-00
Diff to selected 1.6
first verion of top level makefile.  this thing goes into the work directory
and drives the make.
just a comment file right now
