[Bio] / ReleaseTools / Makefile.top Repository:
Log of /ReleaseTools/Makefile.top
Links to rast_rel_2008_07_21: (view) (download) (annotate)
Thu May 19 20:50:55 2005 UTC (14 years, 8 months ago) by efrank
CVS Tags: HEAD, Root-bobdev_news, before-dynamics-persistence, caBIG-00-00-00, caBIG-05Apr06-00, caBIG-13Feb06-00, lwc, makeScriptHeaders, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, mobedac_release_05302012, myrast_33, preTreatmanDyn, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29, treatman-lastDay-0
Changes since 1.18: +3 -3 lines
Diff to previous 1.18
fix typo/ brain fade
Thu May 19 20:41:44 2005 UTC (14 years, 8 months ago) by efrank
Changes since 1.17: +13 -2 lines
Diff to previous 1.17
# We use the wildcard trick again so that we have the dependency
# only if ReleaseTools is checked out.  If not checked out, we
# are by definition satisfied with makeScriptHeaders in the base
# release. Note we must make the dependency be on the source file,
# not the $(bindir) file because if the latter does not exist, the
# wildcard fails and there's no dependency!  But if the ReleaseTools/make*
# exists and is newer, then we just defer to the ReleaseTools target
# used above for decouple:
$(TOPDIR)/$(RTARCH)/tool_hdr: $(wildcard $(ReleaseTools)/makeScriptHeaders)
        cd $(TOPDIR); $(bindir)/makeScriptHeaders $(TOPDIR)
$(TOPDIR)/$(RTARCH)/tool_hdr_py: $(wildcard $(ReleaseTools)/makeScriptHeaders)
$(ReleaseTools)/makeScriptHeaders: ReleaseTools
Mon May 16 21:08:04 2005 UTC (14 years, 8 months ago) by efrank
Changes since 1.16: +16 -2 lines
Diff to previous 1.16
mods re makeScriptHeaders which I see now I forgot to do a cvs add on.
feh.
Sun Mar 13 01:48:05 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.15: +4 -1 lines
Adding css to Makefile
Fri Nov 19 18:10:34 2004 UTC (15 years, 2 months ago) by efrank
CVS Tags: V00-00-15, gunk, post-st-migration, post-st-migration2, stMigration0
Changes since 1.14: +14 -3 lines
changes affecting SchemaTools
Wed Sep 29 15:06:39 2004 UTC (15 years, 3 months ago) by efrank
CVS Tags: sc04-finalDay, sc2004-0, sc2004-1, sc2004-2, sc2004-3, sc2004-4
Changes since 1.13: +141 -45 lines
remove requirement that ReleaseTools must be checked out by adding
a wildcard in determination of dependencies.
add info needed for "include standard.mk" to work in package level makefiles.
should not affect others since new targets are not wired in.
Fri Sep 10 12:54:37 2004 UTC (15 years, 4 months ago) by efrank
CVS Tags: preSchematools
Changes since 1.12: +7 -0 lines
So far, we've allowed each package to define all  kinds of rules in its
makefile.  That's wasteful and makesit hard to improve the system because,
when you want new build capabilities, you have to edit all those makefiles,
and users have to know too much.
Gather the business end of the build into standard.mk.  Have package makefiles
include standard.mk.  Modify Makefile.top to have -I so that package makefile
can find standard.mk.  problem solved.  Now package makefiles only need to
define a few macros to describe what to build.
Fri May 21 17:55:28 2004 UTC (15 years, 8 months ago) by olson
CVS Tags: V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.11: +26 -10 lines
make the makefile check for proper environment
also add tutorial directory creation
Tue May 4 16:26:46 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.10: +19 -11 lines
add rule for updating from ReleaseTools/Makefile.top; use $(cgidir) instead of CGI; remove some verbosity from the output
Fri Mar 5 19:38:56 2004 UTC (15 years, 10 months ago) by olson
CVS Tags: V00-00-07, V00-00-08, V00-00-09
Changes since 1.9: +2 -0 lines
Create CGI/p2p dir now.
Tue Dec 23 19:19:57 2003 UTC (16 years, 1 month ago) by olson
Changes since 1.8: +26 -13 lines
New make structure.
Wed Dec 3 20:10:34 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-06, delong-01, delong-02
Changes since 1.7: +4 -1 lines
make CGI/Html dir
Wed Dec 3 19:07:36 2003 UTC (16 years, 1 month ago) by efrank
Changes since 1.6: +9 -2 lines
add an all: and a clean:
Wed Dec 3 02:43:22 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-05
Changes since 1.5: +6 -0 lines
Handle case where no packages are ni the directory when make installdirs
is iinvokded.  in that case, tmp and lib were not created because there
were no packages and so no dependencies.  handle this by adding two
rules that always makd the top level dirs
Wed Dec 3 01:17:40 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-04
Changes since 1.4: +6 -2 lines
Makefile.top:
	make per package subdirs under lib to hold pyc and other such
	files.
getpakcgae:]
	make a subdir under lib for the new package
Tue Dec 2 23:39:16 2003 UTC (16 years, 1 month ago) by efrank
Changes since 1.3: +18 -1 lines
Mon Dec 1 21:18:51 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-03
fix cgidir by including in override
Mon Dec 1 20:59:29 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-02
Changes since 1.1: +56 -0 lines
add PKGNAME to Makefile.top
add CGI subdir to workdirectory in mkworkdir
Mon Dec 1 15:23:27 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: V00-00-01
mistake in last commmit.  Makefil is the package makefile.  Makefile.top
is the toplevel one.  It will be renamed to Makefile wyhen copied into
the work directory.
