[Bio] / ReleaseTools / Makefile.top Repository:
Log of /ReleaseTools/Makefile.top
Links to V00-00-10: (view) (download) (annotate)
Fri May 21 17:55:28 2004 UTC (15 years, 9 months ago) by olson
CVS Tags: V00-00-10, V00-00-11, V00-00-12, V00-00-13, V00-00-14, forRick-14Jul04-0, forRick-14Jul04-1, mass-spec-01, mass-spec-02, mass-spec-03
Changes since 1.11: +26 -10 lines
make the makefile check for proper environment
also add tutorial directory creation
Tue May 4 16:26:46 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.10: +19 -11 lines
add rule for updating from ReleaseTools/Makefile.top; use $(cgidir) instead of CGI; remove some verbosity from the output
Fri Mar 5 19:38:56 2004 UTC (15 years, 11 months ago) by olson
CVS Tags: V00-00-07, V00-00-08, V00-00-09
Changes since 1.9: +2 -0 lines
Create CGI/p2p dir now.
Tue Dec 23 19:19:57 2003 UTC (16 years, 2 months ago) by olson
Changes since 1.8: +26 -13 lines
New make structure.
Wed Dec 3 20:10:34 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-06, delong-01, delong-02
Changes since 1.7: +4 -1 lines
make CGI/Html dir
Wed Dec 3 19:07:36 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.6: +9 -2 lines
add an all: and a clean:
Wed Dec 3 02:43:22 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-05
Changes since 1.5: +6 -0 lines
Handle case where no packages are ni the directory when make installdirs
is iinvokded.  in that case, tmp and lib were not created because there
were no packages and so no dependencies.  handle this by adding two
rules that always makd the top level dirs
Wed Dec 3 01:17:40 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-04
Changes since 1.4: +6 -2 lines
Makefile.top:
	make per package subdirs under lib to hold pyc and other such
	files.
getpakcgae:]
	make a subdir under lib for the new package
Tue Dec 2 23:39:16 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.3: +18 -1 lines
Mon Dec 1 21:18:51 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-03
fix cgidir by including in override
Mon Dec 1 20:59:29 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-02
Changes since 1.1: +56 -0 lines
add PKGNAME to Makefile.top
add CGI subdir to workdirectory in mkworkdir
Mon Dec 1 15:23:27 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-01
mistake in last commmit.  Makefil is the package makefile.  Makefile.top
is the toplevel one.  It will be renamed to Makefile wyhen copied into
the work directory.
