[Bio] / RegSubMa / rp_correction.pl Repository:
View of /RegSubMa/rp_correction.pl
Revision 1.1.1.1 - (download) (as text) (annotate) (vendor branch)
Wed Apr 4 17:08:51 2007 UTC (13 years, 3 months ago) by mkubal
Branch: MAIN, fig
CVS Tags: v_1_0_0, HEAD
initial checkin
# -*- perl -*-
# Public License.
use strict;
use GenomeMeta;
use FIG;
use FIG_Config;
use strict;
use File::Basename;
@ARGV == 2 or die "Usage: $0 job-dir request\n";
my $jobdir = shift;
my $request = shift;
# Valid requests.
my @valid_requests = qw(remove_embedded_pegs remove_rna_overlaps);
my %valid_requests = map { $_ => 1 } @valid_requests;
-d $jobdir or die "$0: job dir $jobdir does not exist\n";
my $genome = &FIG::file_head("$jobdir/GENOME_ID");
chomp $genome;
$genome =~ /^\d+\.\d+/ or die "$0: Cannnot find genome ID for jobdir $jobdir\n";
my $meta_file = "$jobdir/meta.xml";
my $meta = new GenomeMeta($genome, $meta_file);
my $genome_dir = "$jobdir/rp/$genome";
-d $genome_dir or &fatal("genome directory $genome_dir not found");
$meta->set_metadata("status.correction", "in_progress");
# Determine request from the req argument.
# Comma sep list, possibly with spaces.
my @reqs = split(/,\s*/, $request);
# Ensure we have valid requests.
for my $req (@reqs)
    if (!$valid_requests{$req})
	&fatal("Invalid correction \"$req\" requested");
    my $cmd = "$FIG_Config::bin/$req";
    if (! -x $cmd)
	&fatal("Correction command $cmd for request $req does not exist");
# Process requests.
for my $req (@reqs)
    my $cmd = "$FIG_Config::bin/$req $genome_dir";
    my $err = "$jobdir/rp.errors/$req.stderr";
    $meta->add_log_entry($0, ['start', $cmd]);
    my $rc = system("$cmd >$err 2>&1");
    $meta->add_log_entry($0, ["finish rc=$rc", $cmd]);
    if ($rc != 0)
	&fatal("Correction $cmd failed with rc=$rc");
# And rerun the quality check.
my $cmd = "$FIG_Config::bin/assess_gene_call_quality --meta=$meta_file $genome_dir > $genome_dir/quality.report 2>&1";
my $rc = system($cmd);
if ($rc != 0)
    &fatal("Post-correction assessment $cmd failed with rc=$rc");
$meta->set_metadata("status.correction", "complete");
$meta->set_metadata("correction.running", "no");
sub fatal
    my($msg) = @_;
    $meta->add_log_entry($0, ['fatal error', $msg]);
    $meta->set_metadata("status.correction", "error");
    croak "$0: $msg";
