[Bio] / RegSubMa / RegSubMa.cgi Repository:
View of /RegSubMa/RegSubMa.cgi
Revision 1.1.1.1 - (download) (annotate) (vendor branch)
Wed Apr 4 17:08:51 2007 UTC (13 years, 3 months ago) by mkubal
Branch: MAIN, fig
CVS Tags: v_1_0_0, HEAD
initial checkin
# Public License.
use strict;
use warnings;
use lib '/home/mkubal/PPO/';
use lib '/home/mkubal/public_html/FIGdisk/dist/releases/current/RegSubMa/';
use DBMaster;
use WebApplication;
use WebMenu;
use RegSubMa;
eval {
    &main;
if ($@)
    my $cgi = new CGI();
    print $cgi->header();
    print $cgi->start_html();
    # print out the error
    print $@;
    print $cgi->end_html();
sub main {
    # initialize db-master
    my $dbmaster = DBMaster->new('FortyEight_WebApplication');
    #my $dbmaster = DBMaster->new('MicroArrayData');
    #my $dbmaster = DBMaster->new('DomReg');
    # initialize layout
    my $layout = RegSubMa->new('./Html/FortyEight.tmpl');
    # build menu
    my $menu = WebMenu->new();
    #$menu->add_category( "Logout", "index48.cgi?page=Login&action=logout" );
    #$menu->add_category( "48-hour" );
    #$menu->add_entry( "48-hour", "Upload", "index48.cgi?page=Upload" );
    # initialize application
    my $WebApp = WebApplication->new( { dbmaster => $dbmaster,
					menu     => $menu,
					default  => 'RegSubMa',
					layout   => $layout } );
    # run application
    $WebApp->run();
