[Bio] / RegSubMa / FortyEight.tmpl Repository:
View of /RegSubMa/FortyEight.tmpl
Revision 1.1.1.1 - (download) (annotate) (vendor branch)
Wed Apr 4 17:08:51 2007 UTC (13 years, 3 months ago) by mkubal
Branch: MAIN, fig
CVS Tags: v_1_0_0, HEAD
initial checkin
<html>
  <head>
    <title><TMPL_VAR NAME="TITLE"></title>
    <TMPL_IF NAME="STYLESHEET">
      <link rel="stylesheet" type="text/css" href="<TMPL_VAR NAME="STYLESHEET">">
    </TMPL_IF>
    <TMPL_IF NAME="JAVASCRIPT">
      <script type="text/javascript" src="<TMPL_VAR NAME="JAVASCRIPT">"></script>
      <script src="./Html/ie7-standard-p.js" type="text/javascript"></script>
      <script type="text/javascript">
            // a regular expression to test for Base64 data
            var BASE64_DATA = /^data:.*;base64/i;
            // path to the PHP module that will decode the encoded data
            var base64Path = "./Html/ie7-base64.php";
            function fixBase64(img) {
                  // check the image source
                  if (BASE64_DATA.test(img.src)) {
                        // pass the data to the PHP routine
                        img.src = base64Path + "?" + img.src.slice(5);
            // fix images on page load
            onload = function() {
                if (navigator.appName == "Microsoft Internet Explorer") {
                     for (var i = 0; i < document.images.length; i++) {
                         fixBase64(document.images[i]);
      </script>
    </TMPL_IF>
  </head>
  <body>
    <div id="header">
      <span id="logo">
	<img height="95px" src="<TMPL_VAR NAME="LOGO">" alt="<TMPL_VAR NAME="LOGO_ALT">" />
      </span>
      <p>
	<span id="title">
	  <img src="<TMPL_VAR NAME="TITLE_IMAGE">" alt="<TMPL_VAR NAME="TITLE_ALT">" />
	</span>
	<span id="version"><TMPL_VAR NAME="VERSION"></span>
      </p>
      <p><TMPL_VAR NAME="TITLE_DESCRIPTION"></p>
    </div>
    <TMPL_IF NAME="MENU">
    <TMPL_VAR NAME="MENU">
    </TMPL_IF>
    <div id="content">
      <TMPL_VAR NAME="CONTENT">
    </div>
    <div id="footer">
      <TMPL_VAR NAME="FOOTER">
    </div>
  </body>
</html>
