[Bio] / RecoElemSBW / SbwFactory.hh Repository:
Log of /RecoElemSBW/SbwFactory.hh
Mon Sep 22 20:12:04 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: HEAD
Changes since 1.4: +11 -1 lines
dumptoSbml
	give it a RecoId and it dumps SBML
SbmlFactory:
	put in int() for stoich conversions.  may not be right.
SbwFactory:
  	support writing SBML.
Fri Sep 19 04:18:17 2003 UTC (16 years, 2 months ago) by efrank
Adding ability to write out sbml.  temporary sync with cvs.
Thu Sep 18 23:24:48 2003 UTC (16 years, 2 months ago) by hwang
	Fixed spelling mistakes. Everything compiles now.
Thu Sep 18 21:18:40 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.1: +13 -1 lines
Move all of SbmlFactory into SbwFactory and migrate SBMLtoRecoElem to
match.
SBMLtoRecoElem.cc:
   makes an SbwFactory rather than SbmlFactory and then uses it
SbmlFactory.cc, SbmlFactory.hh:
SbwFactory.{cc,hh}
   Now has guts fo SbmlFactory plus skeleton for writeToSbmlFile(char* filename)
Mon Jul 7 17:52:33 2003 UTC (16 years, 4 months ago) by efrank
Class to act as factory for RecoElem's as for BssFactory in RecoReadoutOracle.
This one gets stuff from the RecoElemSBWServer.
Probably should move the Sbml converter into this as the dependencies are
consistent.
