[Bio] / RecoElemSBW / SbmlFactory.hh Repository:
Log of /RecoElemSBW/SbmlFactory.hh
Thu Sep 18 21:18:40 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: HEAD
Move all of SbmlFactory into SbwFactory and migrate SBMLtoRecoElem to
match.
SBMLtoRecoElem.cc:
   makes an SbwFactory rather than SbmlFactory and then uses it
SbmlFactory.cc, SbmlFactory.hh:
SbwFactory.{cc,hh}
   Now has guts fo SbmlFactory plus skeleton for writeToSbmlFile(char* filename)
Thu May 22 19:25:22 2003 UTC (16 years, 6 months ago) by efrank
Diff to selected 1.2
put sbml->recoelem into a factory so it can be called, i.e., take it out of main() in the r&d executable
