[Bio] / RecoElemSBW / SbmlFactory.cc Repository:
Log of /RecoElemSBW/SbmlFactory.cc
Mon Sep 22 20:12:04 2003 UTC (16 years, 1 month ago) by efrank
CVS Tags: HEAD
dumptoSbml
	give it a RecoId and it dumps SBML
SbmlFactory:
	put in int() for stoich conversions.  may not be right.
SbwFactory:
  	support writing SBML.
Thu Sep 18 21:18:40 2003 UTC (16 years, 1 month ago) by efrank
Changes since 1.4: +0 -3 lines
Move all of SbmlFactory into SbwFactory and migrate SBMLtoRecoElem to
match.
SBMLtoRecoElem.cc:
   makes an SbwFactory rather than SbmlFactory and then uses it
SbmlFactory.cc, SbmlFactory.hh:
SbwFactory.{cc,hh}
   Now has guts fo SbmlFactory plus skeleton for writeToSbmlFile(char* filename)
Thu Sep 18 19:05:25 2003 UTC (16 years, 1 month ago) by hwang
Changes since 1.3: +26 -25 lines
	SbmlFactory.cc
	   Added getReactionModifier
Thu Sep 4 19:25:41 2003 UTC (16 years, 2 months ago) by hwang
Changes since 1.2: +42 -10 lines
	SbmlFactory.cc
	   Added getReactionModifier function. This gets a list of modifier for each reaction.
Tue Jul 29 19:34:32 2003 UTC (16 years, 3 months ago) by efrank
Migrate to libsbml-2.0.0.   Mostly List and ListOf migrations.  not sure i
really understand what i'm doing.
Thu May 22 19:25:22 2003 UTC (16 years, 5 months ago) by efrank
put sbml->recoelem into a factory so it can be called, i.e., take it out of main() in the r&d executable
